TR4/4A Door glass assembly help please.
Its pretty much center. Install everthing, roll the window up and carefully shut the door. You want to adjust the glass to fit properly against the windshield frame. There is a stop in the bottom center of door that sets how far down the glass can go. Take it out and roll the glass down as far as it will go to give you more room to install the rubber and fuzzy seal. Let the glass find its own center.
Marv
M
malbaby
Thanks Marvin.
I have refurbished my glass runner channels, pop riveting the original attachment brackets onto new channel.
However when reinstalling the channels I found that they are slightly off centre, so I may have to drill out the rivets and redo the attachment brackets so that the channels are dead centre.
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
R TR6 TR6 Door Glass Triumph 5
H General Tech Door Glass outer seals installation Triumph 6
M TR4/4A TR4 door glass spacer wires. Triumph 1
M TR4/4A Door glass bayley channel clearance measurement. Triumph 4
M TR4/4A Sequence for fitting door glass? Triumph 7
S door glass inner seal Austin Healey 6
T BJ8 door glass replacement Austin Healey 4
maxwedge5281 bj7 door glass and pin questions! Austin Healey 0
B Setting door glass Austin Healey 3
1 Door Glass Seals Spridgets 6
I Door glass Austin Healey 11
TR4nut TR4/4A Anyone have any spare TR4/4A door glass? Triumph 12
I Door Glass Austin Healey 8
T Door glass, bottom channel Spridgets 4
D door glass removal Spridgets 7
jjbunn Door Glass Glazing Strip Triumph 4
M Door Vent Glass Austin Healey 5
Brosky Victory over the "evil door glass gremlins" Triumph 2
P Door Glass came loose... Spridgets 8
AUSMHLY Door Glass Austin Healey 31
Editor_Reid BJ8 Door Glass Austin Healey 6
Jack_Long Need help with door glass MG 2
J door window glass MG 2
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 6
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
D MGB Older style door pulls MG 0
V Door Seals Austin Healey 8
Bayless Door seal question Spridgets 3
Donald1107 TR2/3/3A Door hinges Triumph 14
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
D Door Seal Fit Austin Healey 18
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
E 3000 Healey Door Checks Austin Healey 1
A MGB MGB a glove box door MG 10
