The leak is right in the top corner at the end of a tube at the last of the cooling fins were the tube meets the tank. I went out last night after spending most the day feeling like incompetent craftsman, and flip the radiator over and put some solder on the leak and fix it. Perhaps the radiator shop did not want some hillbilly fixing his own stuff, but this guy knows me from when I worked at the university, so he might even think I am a hopeless academic. I got looking close at the crank hole and those tubes are do not even open; they are sealed in the core, so I am not sure why he was so critical of my work. But and again I spent 20 years in the carpenters union and know how critical others can be in a competitive way.
There are no leaks now and I am working on figuring a way to do a light pressure test. I might just put it in the car and run it. Somewhere I have a brake fluid canister lid with an air nipple to put some pressure on hydraulic fluid. I thought I could put that in at the cap opening with some duct tape or somehow then turn down the compressor to 5 psi and try that. What did you do John to pressure test? Moreover, I need to put the sides back on and I was thinking of using 60/40 because I think it has a lower melting point and would lessen the chances of opening a leak in a tank. I used 50/50 on the main assembly and the solder laid down kinda thick, maybe that is a good thing radiator I do know.
Now I have most of good second radiator that I might put together, but the top tank in kinda cheese. I thought it was home made, but maybe it is aftermarket from the 80ites. I took a picture to show the 3 rows as opposed to the 5.
steve
steve
