Atrus
Hey everyone.
I've read over numerous threads on the DIY temp gauge repair and decided to try it myself. I made a small brass adapter as the old tubing is a little larger than the new.
I have a 230 watt solder gun. I purchased some plumbing solder and flux, ~400 degree F melting point. I am definitely a novice at soldering - I understand the concept, but I don't have a lot of experience in applying it.
I cannot get the tube and adapter on the old gauge to heat up enough to solder the joint.
How did you all do it?
