DIY Michelin Red Line - 205/70R15
RobT
Given all the recent discussion of TR tires, I thought I would share my own experiment in this area.
I had some very old (+10 yr) set of Michelin 205/70R15 red line radials on the car. They were starting to crack and go out of round, so even though the tread was fine, it was time to look for a replacement.
I wanted to use a modern tire like the ones fitted, preferably a 205/70R15, rather than the old 185's, but could not find anyone who makes a red-line tire in this size anymore. I did, however, find a Michelin Symmetry "white line", which comes with a narrow white stripe on the sidewall(as the name suggests). So I bought a set of these (about $130 each, fitted and balanced), and painted the white line "red". Here is the result:
And they look pretty close to the old Michilen "X" 185s
I used some red vinyl spray paint (purchased from the local auto parts store - for recolouring interiors) applied with a paint brush. The width of the white lines is supposed to be 1/2 inch, while the originals are 3/8 inch, but by my measurements they are both pretty darn close to 7/16.
Michelin "X":
Michelin Symmetry:
The tread patterns are different, you can see the Symmetry is wider and slightly shorter than the "X":
The Symmetry is an all-weather tire - I would have preferred a summer performance tire, but they are a vast improvement over the old ones, and I suspect give better handling than the "X". I am yet to see if the paint washes off in the first rain storm though.
Rob.
roofman
Good idea!!!!!!!!!!!!!!
kodanja
they look real good, I bet they feel real nice too!
PeterK
They look really good but would look excellent if you washed the brake dust off the rim. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
Just kidding, they look great! OK maybe not kidding ...
R6MGS
I like that idea! I am impressed and thankful!
bricktop
By the way, Coker Classic does make a 205/75 R15 redline with a 3/8 stripe. They are about 163.00 apiece. I am about to buy some myself.
T
Tinster
Great concept, fine looking tires!!
I wonder if the local bakery could powder coat
a set of tires with red lines? Does rubber
burn at 400* F ??
d
RobT
RobT
Thanks guys.
Have to admit I was quite pleased with myself. Just sometimes I get it right.
Do excuse the break dust on the front wheel pic - guess that's what happens when you drive your car.
Rob.
Brosky
I wouldn't want anything out of that oven when the tires were done....
G
It's been a while now, I was wondering how the red vinyl paint has held up?
vettedog72
The appearance is great! Also, the picture makes the "new" tire look wider and a little less in diameter than the old red line Michelin. Is there a difference or is it just the pictures? What brand paint, how many coats and how does it due after some mileage?
Great idea.
RobT
RobT
The tires are standing up O.K. I did get a little flaking, but think that was my own fault. I used "Kolorcote" or some such brand from my local auto parts store, and the can says "use above 65 deg", and it was about 50 deg out when I painted the wheels. I think I'll re-do them using the Dupoint vinyl dye when I get a chance.
Rob.
DNK
They make actual tire paint. It is in a roller pen.
H
HGH
Dear Rob,
I'm the proud owner of an early TR6 PI ( 150 BHP ) and it desperately needsnew tires, thats why I reply to your message.
Do you know if those Redliners are still fabricated and are they also available in the size 185 R15 and at what price do they come???
I want to buy 5 ( including spare )of them if the price and shipcost is reasoanble.
Waiting for your answer I sincerly greet you.
Henk from Holland ( Netherlands )
DNK
E-Gads that's an old post.
Henk- You can get modern tires with that red line on them now. I didn't save any info as it was not pertinent to me but someone will pipe in.
Welcome to the zoo!
Joel Lester TR2/3/3A DIY paint job? vs leave it to the professionals? Triumph 27
Hamish Racing TR2/3/3A Sway bar rose joints and diy brackets Triumph 4
PC DIY tips from Bo his self Other Cars 0
tahoe healey DIY Extension for Clutch Bleeding Austin Healey 23
K TR2/3/3A Sloppy SU linkage and DIY bellcrank repair? Triumph 6
K TR2/3/3A DIY Alternator heat shield>>> Triumph 2
K TR2/3/3A DIY TR3A Rack and Pinion Steering Conversion Triumph 0
S TR2/3/3A DIY radiator rebuild and rod out Triumph 26
maxwedge5281 diy side curtain polishing Austin Healey 8
Joe Reed MGB DIY splash shield for 77-80 MGBs... MG 0
Joe Reed MGB DIY Late MGB Mud Shield MG 0
oud272 New Paint - DIY Spridgets 17
jaegzie Looking for a write up on diy carpet mentioned in other posts Spridgets 9
K TR2/3/3A Can porting a TR3 Cylinder head be a DIY job? Triumph 6
T TR2/3/3A Upholstery Shop or DIY Triumph 16
Schroeders T-Series TF Tach Calibration - DIY? MG 3
D DIY - Front tube shock conversion Spridgets 33
M Ultimate DIY Triumph 2
D DIY-Roller-Throw-Out-Bearing Spridgets 2
RAC68 DIY Roller Throw Out Bearing Austin Healey 14
Morris DIY Dash Spridgets 20
K TR2/3/3A TR3 water pumps again...DIY? Triumph 0
boxfullofyertoys Thoughts on DIY welding/bodywork Spridgets 27
K TR2/3/3A Rebuilding a TR3 Lever Shock DIY? Triumph 8
B TR6 DIY TR-6 frame repair feasibility- Triumph 15
HealeyRick DIY Carb Cleaning Soda Blaster Austin Healey 2
T perils of DIY paint jobs Triumph 14
K DIY Gas Tank Flush Triumph 5
Atrus DIY Temp gauge repair - Solder issues Spridgets 40
RickB First DIY front alignment. Spridgets 5
tosoutherncars Front shock R&R instructions / pix / DIY? Spridgets 10
DrEntropy Anyone interested in DIY front-end alignment? Restoration & Tools 14
T Raise Seat Height - DIY Triumph 1
CraigLandrum TR2/3/3A DIY TR3A Seat Covers Triumph 13
T Install Lower A-arms-DIY Triumph 0
beaulieu DIY powder coating , how good does it work ? Restoration & Tools 10
JPSmit DIY Carpet Question Spridgets 12
eschneider diy ultrasonic cleaner Restoration & Tools 5
Randy Harris Ran across cool car-guy show on DIY channel Austin Healey 5
RobSelina DIY rear tube shock ideas [finished w/ pics] Spridgets 18
RobSelina need some help with DIY spring arching/de-arching Spridgets 9
john_j DIY Rag Top? Other British Cars 1
R Transmission Rebuild DIY? MG 5
Rick O. DIY Pressure Bleeder Restoration & Tools 5
red57 Michelin XAS Tires Austin Healey 38
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
T TR2/3/3A Michelin vs Vredestien Triumph 20
I For Sale Minilite replicas with Michelin tires $400 Triumph Classifieds 16
S Michelin XAS tires for my '67 Austin Healey 3000 Austin Healey 16
jfarris Michelin Cars and Coffee 8/27 in Greenville, SC Spotted 2
