Crankshaft pulley / damper
Cooperman
Member
Hi - I've been putting my 3000 Mk1 engine back together and realised the original vibration damper pulley is broken. I do have one from a Wolseley 6/110 which looks to be OK is the same diameter fan belt pulley but has a different damper design.
Question - would it be Ok on the 3000? Any one used one of these?
Thanks
British_Recovery
Bronze
I don't know about that, but have replaced the original on an early 3000 with the one from Moss ( part # 031-206 ).
Very good results, and a good quality part.
How's the rubber lamination look? Given their age, and seeing the damage that a failed damper can do, there's just No Way I would put any 50 - 60 year-old damper on an engine without sending it out to a professional for rebonding first.
Just my opinion, of course.
John Turney
Having had an old damper break, I agree with Randy. If you want a better damper and aren't into Concours, go with the Moss one.
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
Colin8 1098/1275 Crankshaft Pulley - Damper Spridgets 3
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
M TR2/3/3A Crankshaft Pulley Configurations Triumph 3
GTP1960 TR2/3/3A Moss Crankshaft pulley failure Triumph 23
M For 1974 MG Midget - Crankshaft pulley bolt is 1 5/16"? Spridgets 4
M Spitfire need a crankshaft pulley for 1978 Spitfire Triumph 0
vette Timing Cover crankshaft pulley seal Austin Healey 6
Tugboat Crankshaft Pulley Question Triumph 4
regularman Crankshaft pulley nut for 1500 engine Triumph 5
kyreb1862 80 B Crankshaft Pulley MG 6
R Crankshaft pulley bolt MG 8
abarth69 Crankshaft pulley bolt Spridgets 1
tony barnhill 1275 Crankshaft Pulley Spridgets 2
BritSpit Removing Crankshaft Pulley Nut Triumph 22
R 1500 midget crankshaft pulley nut removal? Spridgets 2
Brosky TR6 Diameter of crankshaft pulley on TR6 Triumph 17
B Spare crankshaft pulley for BN1? Austin Healey 0
G loose pulley on crankshaft Triumph 3
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
B TR6 Crankshaft long seal surface Triumph 5
MKIII_Joey Crankshaft Bearing Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
B General MG Crankshaft Nut Removal MG 4
W Crankshaft Oil Seal Austin Healey 3
B MGB Mgb crankshaft end play shims MG 2
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
T crankshaft (rear) bearing leak Spridgets 2
T Wanted Wanted - 1956 TR3 Crankshaft Triumph Classifieds 0
R Wanted 3 main crankshaft MG Classifieds 0
glemon TR2/3/3A Crankshaft Question Triumph 3
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
AUSMHLY Crankshaft Starter Nut Austin Healey 10
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
P TR2/3/3A Crankshaft Thrust Washers Triumph 4
M TR2/3/3A Crankshaft Oil Galley Plugs Triumph 7
S TR4/4A Fair price for a crankshaft? Triumph 2
charleyf TR2/3/3A crankshaft hardening Triumph 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
G Crankshaft Rotational Freeplay - What's going on with this engine? Austin Healey 12
O Wanted TR 3 Crankshaft please... Triumph Classifieds 1
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
C Tough Bolt on front of Crankshaft Spridgets 16
TRMark TR4/4A Prepping Crankshaft Triumph 4
D TR2/3/3A crankshaft shims to align timing sprovkets Triumph 4
