TR2/3/3A Cog v-belt causing noise.
Lukens
I just replaced my generator with an alternator. I kept my original wide belt pulley. Today I took a 150 mile drive and could hear a "whirring" sound coming directly from the alternator. Got home and took the belt off. The bearings sound and feel fine (spinning by hand). I used a cog belt (top and bottom cogs) and had the tension set properly. Could it be that I'm hearing the belt contacting the v groove in the pulley? If that's the case I can live with the sound.
Russ
TR3driver
Great Pumpkin - R.I.P
I'd be looking for where the rotor or the fan is just kissing something, under the load from the belt.
Or is this like the old Rolls Royce commercial with the loud clock?
Lukens
Lukens
I put the old solid v belt on and the noise went away. Apparently the cogs need a few miles to conform to the pulley.
And yes, it may be a case of the loud clock. Since I had the head reworked, the motor runs much smoother and quieter.
CJD
I'm worried about your mufflers. They are way to quiet if you can hear a belt whirring!
martx-5
That's not as bad as arguing with yourself.
C MGB Should I lubricate the cog gears MG 2
D TR2/3/3A layout for lap type seat belt Triumph 5
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
K TR2/3/3A Overtightening the alternator belt? Triumph 14
D T-Series Shorrock supercharger drive belt MG 7
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
M 1972 Midget Seat Belt Replacement Spridgets 4
Lin Fan belt for 1275 with alternator Spridgets 4
nichola TR6 Seat belt reinforcing plate question Triumph 15
NutmegCT Belt preservative? Restoration & Tools 6
2 TR2/3/3A V-belt obstruction Triumph 0
Michael Oritt Seat belt anchors--introduction Austin Healey 2
T BJ8 Fan Belt Change Austin Healey 7
longbridgehealey Bonnet belt Austin Healey 16
B TR6 TR6 Fan Belt Triumph 4
F TR6 Seat Belt Module? Triumph 4
tahoe healey past post about sholder belt foam Austin Healey 2
M TR2/3/3A Water Pump Belt After Alternator Conversion Triumph 6
B Wanted Kangol Seat Belt Receiver Jaguar Classifieds 5
B Wanted Kangol Seat Belt Receiver Triumph Classifieds 0
steveg BJ8 Alternator - small belt in large pulley Austin Healey 4
I General TR Seat belt dissassembly help Triumph 0
I TR6 Seat belt restoration Triumph 1
C TR6 Seat belt warning bypass for new harness. Triumph 6
KVH TR4/4A Belt Size for TR4A Triumph 4
G TR2/3/3A Fan belt Triumph 6
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
2billydavies TR2/3/3A belt size for TR3a? Triumph 13
M TR4/4A Narrow belt conversion with thermo fan. Triumph 0
C "Belt Type" squeal BN1 - Throw out bearing? uh oh... Austin Healey 14
B TR6 Seat Belt Brackets - Any Better Ideas? Triumph 1
J TR2/3/3A Changing fan belt. Triumph 9
C MK1 3000 fan belt Austin Healey 1
Lin Pulley and belt configuration for air conditioning Austin Healey 2
Lukens TR2/3/3A Narrow belt conversion. I can't understand why... Triumph 25
GTP1960 TR2/3/3A Moss alternator & narrow belt conversion questions Triumph 22
T TR2/3/3A Question on spacer in Moss thin belt/damper conversion kit 837-508 Triumph 3
J TR2/3/3A Local fan belt supplier. Triumph 7
J General TR Narrow Belt crank pulley Triumph 0
croz TR2/3/3A Harmonic Balancer - narrow belt pulley Triumph 12
M TR2/3/3A 3/8" belt and pulley conversion kit Triumph 10
M TR2/3/3A Another seat belt question Triumph 8
Jeepster Seat belt fixing Austin Healey 4
B Gen/waterpump belt Austin Healey 13
Jim_Gruber Seat Belt Mounting Points for a BE Spridgets 2
longbridgehealey Hood belt Austin Healey 2
M TR2/3/3A TR-3A - 1960 - 3/8 belt kit Triumph 3
Z 100 Wide Belt Generator Pulley Austin Healey 5
T seat Belt Buzzer Wont shut off Triumph 5
