Clutch Slave Cylinder Travel
Olafthor
I'm getting about 1/2" of slave cylinder rod travel after rebuilding both the master cylinder and installing a new slave cylinder on my TR6. I can engage the gears...just barely with a bit of grinding while the engine is running. Is this a hydraulic or clutch problem? About how much throw is typical for the slave cylinder rod?
Many Thanks,
Daniel
bash
Hi Daniel
I would say that 1/2 inch is a bit short - but the measurement is open to a bit of error as it is in an awkward place and a theoretical maximum movement is only about 3/4 inch or so, as I recall. I am sure someone will have the exact number handy...
Assuming you are only getting 1/2 inch, then I think you probably have a hydraulics problem - have you tried bleeding the slave with it vertical? Unfasten the clevis pin from the drop arm and remove the mounting plate (complete with slave clyinder) from the bellhousing/engine - then with the cylinder almost vertical push the push rod into the cylinder while opening the bleed nipple. Someone on this board advised me to try it and I found I got some more air out even after I was sure there was none left. Sadly after all that I still had to pull the gearbox thanks to a broken taper pin...
Hope that helps
Alistair
O
Olafthor
Thanks for the idea and info. I'll try the vertical method tomorrow am.
Sincerely,
Daniel
Geo Hahn
[ QUOTE ]
...Sadly after all that I still had to pull the gearbox thanks to a broken taper pin...
[/ QUOTE ]
I'll second the 5/8" remark. You might try this test to see if it is a small bit of air still in there -- you under the car, assistant in driver's seat working the pedal. Measure the movement of the slave (just to be sure of the 1/2") then have the assistant pump the pedal repeatly several times.
If there is air in there the repeated pumping will usually get the slave to move a bit more as you are compressing the air a bit more than one pump will do.
If this test &/or more bleeding doesn't do it than maybe you need to ponder that 'dreaded clutch fork pin'.
BTW -- confirm that you have the spring in place that returns the fork arm and that it is in the correct (middle) of the three holes.
Some have resorted to using the top hole rather than the middle to get a bit more action on the clutch fork (at the expense of slightly increased pedal effort). Not ideal, but something to keep in mind I guess.
YankeeTR
I just visited the Revington TR site...they address this problem and suggest you check all of the meachanical linkages for wear. If any parts are worn, an adjustable pushrod should be substituted for the OEM rod.
They also say that a good indication of this problem is having problems putting the trans into reverse or second (most likely to have a worn syncro)...
K New Clutch Master/Slave Cylinder Austin Healey 1
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
WHT Remote Clutch Slave Cylinder Bleed Extension Austin Healey 11
BobHaskell For Sale Clutch Slave Cylinder Bleeder Extension Austin Healey Classifieds 13
R clutch slave cylinder Triumph 11
R Bug-eye clutch slave cylinder and brake cylinder kit interchange Spridgets 1
B MG midget Clutch slave cylinder Spridgets 5
WillR MGB new clutch slave cylinder MG 3
GTP1960 TR2/3/3A Clutch slave cylinder / push rod alignment Triumph 10
trotti Access to the clutch slave cylinder bleed screw Austin Healey 41
F BT7 3000 - Push rod problem on clutch slave cylinder Austin Healey 7
TomChar TR6 '74 Clutch Slave Cylinder location Triumph 8
G MGB Clutch Slave Cylinder MG 34
6 Recommended clutch slave cylinder pushrod clearance Spridgets 6
C 1961 3000 Recommendations for Clutch Slave Cylinder Austin Healey 5
CanberraBJ8 Stripped thread on clutch slave cylinder mount. Options? Austin Healey 9
J T-Series clutch Master cylinder or slave? MG 8
Boink Clutch Slave Cylinder dribble... Spridgets 20
L 1275 Clutch Slave Cylinder to BE Clutch Line Spridgets 14
M TR2/3/3A Position/Adjustment of TR3A Clutch Slave Cylinder Triumph 20
Darrell_Walker TR4/4A TR4A clutch slave cylinder adjustment Triumph 2
Hairyone clutch slave cylinder Spridgets 14
M clutch slave cylinder? Triumph 5
T TR2/3/3A TR3 clutch slave cylinder Triumph 14
A MIDGET 76 1500 CLUTCH SLAVE CYLINDER Spridgets 1
T TR4/4A TR4A clutch slave cylinder Triumph 9
B T-Series Clutch slave cylinder MG 15
mountainman tr 3 clutch slave cylinder Triumph 7
T Any tips on bleeding the clutch slave cylinder? Triumph 6
Bruce_B Anyone have a picture of Clutch Slave Cylinder.... Spridgets 4
JPSmit Qucik Question #1 Clutch slave cylinder Spridgets 2
Michael Oritt Clutch slave cylinder ID help needed Spridgets 3
Michael Oritt Clutch slave cylinder ID help needed Racing 3
MadRiver Speedbleeders for Clutch Slave Cylinder Triumph 3
6 clutch slave cylinder Triumph 2
tony barnhill Clutch Slave Cylinder Spridgets 17
roofman TR6 Tr6 clutch slave cylinder replacement Triumph 11
RedTR3 TR2/3/3A TR3 Clutch Slave Cylinder Adjustment Triumph 3
L T-Series Clutch Slave Cylinder Tubing MG 5
danielnorton After Marke slave cylinder for clutch hydraulics? Spridgets 20
SherpaPilot Clutch Slave Cylinder Mount Position Triumph 4
T Clutch slave Cylinder HELP Triumph 3
M TR4/4A TR4 CLUTCH SLAVE CYLINDER Triumph 2
Z Clutch Slave Cylinder Rebuild Austin Healey 3
Z Clutch Slave Cylinder Rebuild Spridgets 2
Slider748 Clutch slave cylinder question. Help! Triumph 8
F clutch slave cylinder Austin Healey 12
W Clutch Slave Cylinder. Triumph 2
Alan_Myers TR4/4A TR4 clutch slave cylinder - stuck! Triumph 14
