Clutch slave cylinder question. Help!
Slider748
After a great drive, I parked my TR6 and came out an hour later to move the car. To my surprise, the clutch pedal had dropped about halfway down and I couldn't disengage the tranny. I jacked up the car and notice some oil dripping from the clutch slave cylinder. I pulled on the rubbber boot (where the push rod goes in) and it tore apart. About 2 tablespoons of fluid poured out. I figured the problem was just the seal so I purchased a new seal and rubber boot. I've re-installed the slave cylinder and now I have a problem. When I attach the push rod back to the tranny drop arm, the position of the push rod is at full extension. In other words, the push rod can't travel any further to disengage the tranny. Please go easy on me if I'm doing something really stupid here.
Your help is greatly appreciately!
Geo Hahn
Not a TR6 guy so ignore if this doesn't apply... might you have bolted the slave cylinder to the wrong side of the bell housing? I have seen this happen on other LBCs.
AltaKnight
If Geo is not correct then it looks like the clutch arm that the slave pushrod attaches too has moved further away which unfortunately likely means the dreaded taper pin inside has let go meaning the gearbox has to come out.
Check by trying to move the clutch arm by hand without the slave rod attached. If you've got a load of loose play then that's the answer, hope I'm wrong!
martx-5
/ubbthreads/images/graemlins/iagree.gif...This sounds like the taper pin problem. All the symptoms point to it.
G
Ack, that sucks if it is the pin.
I just got done doing a clutch job on my TR6. My pin was sheared also, but somehow it was all staying together. I did the job because the clutch plate had just worn out and it was slipping. Do yourself a favor if the pin is broken. In addition to replacing it with a new high strength hardened pin, take the cross shaft and release fork down to a machine shop and have them drill a hole for a second pin. My buddy did this on mine for me, he drilled through on the opposite side of the fork from the original, at 90 dgrees to the original hole. I then used a grade 8 hardened bolt and a nyloc nut with locktite. Should last for quite awhile that way (I'm hoping).
Slider748
Slider748
Ugh, I was worried someone would say it's the taper pin. However, I checked the play on the clutch arm and there is maybe a 1/4" of play which maybe (hopefully) means the taper pin isn't broken? I also checked to see if I reinstalled the slave on the wrong side of ther bell housing and it seems o.k.
Thanks for the great feedback so far! I'll crawl under the car tonight and spend another hour or so staring at it...
jsneddon
The slave location is essentially a fixed point(if you did in fact install the slave on the right side). So if the clutch arm is already at the far end of the slave travel then it pretty much has to be a mechanical problem at the arm "system" (arm, shaft, pin, fork, T.O. bearing, clutch).
Something in there broke - probably the taper pin.
I'm afraid the transmission is going to need to come out.
Slider748
Slider748
Thanks for the input everyone. I guess I'll be hauling out the tranny this weekend.
K New Clutch Master/Slave Cylinder Austin Healey 1
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
WHT Remote Clutch Slave Cylinder Bleed Extension Austin Healey 11
BobHaskell For Sale Clutch Slave Cylinder Bleeder Extension Austin Healey Classifieds 13
R clutch slave cylinder Triumph 11
R Bug-eye clutch slave cylinder and brake cylinder kit interchange Spridgets 1
B MG midget Clutch slave cylinder Spridgets 5
WillR MGB new clutch slave cylinder MG 3
GTP1960 TR2/3/3A Clutch slave cylinder / push rod alignment Triumph 10
trotti Access to the clutch slave cylinder bleed screw Austin Healey 41
F BT7 3000 - Push rod problem on clutch slave cylinder Austin Healey 7
TomChar TR6 '74 Clutch Slave Cylinder location Triumph 8
G MGB Clutch Slave Cylinder MG 34
6 Recommended clutch slave cylinder pushrod clearance Spridgets 6
C 1961 3000 Recommendations for Clutch Slave Cylinder Austin Healey 5
CanberraBJ8 Stripped thread on clutch slave cylinder mount. Options? Austin Healey 9
J T-Series clutch Master cylinder or slave? MG 8
Boink Clutch Slave Cylinder dribble... Spridgets 20
L 1275 Clutch Slave Cylinder to BE Clutch Line Spridgets 14
M TR2/3/3A Position/Adjustment of TR3A Clutch Slave Cylinder Triumph 20
Darrell_Walker TR4/4A TR4A clutch slave cylinder adjustment Triumph 2
Hairyone clutch slave cylinder Spridgets 14
M clutch slave cylinder? Triumph 5
T TR2/3/3A TR3 clutch slave cylinder Triumph 14
A MIDGET 76 1500 CLUTCH SLAVE CYLINDER Spridgets 1
T TR4/4A TR4A clutch slave cylinder Triumph 9
B T-Series Clutch slave cylinder MG 15
mountainman tr 3 clutch slave cylinder Triumph 7
T Any tips on bleeding the clutch slave cylinder? Triumph 6
Bruce_B Anyone have a picture of Clutch Slave Cylinder.... Spridgets 4
JPSmit Qucik Question #1 Clutch slave cylinder Spridgets 2
Michael Oritt Clutch slave cylinder ID help needed Spridgets 3
Michael Oritt Clutch slave cylinder ID help needed Racing 3
MadRiver Speedbleeders for Clutch Slave Cylinder Triumph 3
6 clutch slave cylinder Triumph 2
tony barnhill Clutch Slave Cylinder Spridgets 17
roofman TR6 Tr6 clutch slave cylinder replacement Triumph 11
RedTR3 TR2/3/3A TR3 Clutch Slave Cylinder Adjustment Triumph 3
L T-Series Clutch Slave Cylinder Tubing MG 5
danielnorton After Marke slave cylinder for clutch hydraulics? Spridgets 20
SherpaPilot Clutch Slave Cylinder Mount Position Triumph 4
O Clutch Slave Cylinder Travel Triumph 5
T Clutch slave Cylinder HELP Triumph 3
M TR4/4A TR4 CLUTCH SLAVE CYLINDER Triumph 2
Z Clutch Slave Cylinder Rebuild Austin Healey 3
Z Clutch Slave Cylinder Rebuild Spridgets 2
F clutch slave cylinder Austin Healey 12
W Clutch Slave Cylinder. Triumph 2
Alan_Myers TR4/4A TR4 clutch slave cylinder - stuck! Triumph 14
