Anyone have a picture of Clutch Slave Cylinder....
Bruce_B
mounted onto the Datsun 5 speed Transmission. I'm using the slave and trans. from Rivergate with a 1275 engine.
Thanks....
JerryB
Its very similar to the 1098-1275 slave but a little shorter. on the back end as part of the casting there is a block with the bleed scru and inlet fitting. The pushrod is threaded.
Look in a paper pictorial catalog, Bendix, Centric or whomever in the clutch slave section.
this is a discription of the oem Datsun/Nissan piece that came on those trans. "form Rivergate might have modifications for the Spridget throw out arm. And BTW there is three different bores availaible.
Baz
Westfield_XI
I don't have a pic, but as I recall it must be mounted upside down from the stock location. There are two drilled and tapped lugs on the bracket that lift it enough to have clearance in the upside down location. On my Speedwell oil pan there was an issue of contact at the left rear corner of the pan and I had to have the pan modded to clear. This won't be a problem with a stock pan.
Bruce_B
Bruce_B
Thanks all....be putting it on tonight. Just finished bleeding it.
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
B MGB anyone have a good picture of a 78 MGB dashboard? MG 2
richberman picture of radiator side shields anyone? Austin Healey 10
H Picture of an original choke knob BJ7 anyone? Austin Healey 16
richberman Picture of BN4 Rocker panel anyone Austin Healey 0
pjsmetana Spitfire Anyone have a nice Spitfire Trunk / Boot picture? Triumph 2
Brosky Can anyone spot the Mustang in this picture [ebay] Triumph 9
W Anyone have a picture of this tool? Restoration & Tools 2
Basil Anyone remember Dave Russell? Austin Healey 9
AngliaGT Anyone Plan on Attending the SCCA Runoffs at VIR Next Week? Racing 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
Celtic 77 Anyone recall Hobo Hill in New York State? Racing 0
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
JPSmit Gear reduction starters anyone? Restoration & Tools 5
L Can anyone tell me what car this is from please? Other Cars 0
DrEntropy Show this to anyone under 40... Restoration & Tools 9
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
D Can anyone identify this vintage car? Other British Cars 17
T Can anyone identify this bumper Spridgets 5
AngliaGT Morgans - Anyone Heard From John Sheally lately? Other British Cars 13
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
roscoe Comments, anyone? Austin Healey 3
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
B Anyone have a Europa Twin Cam for sale? Lotus 6
B Anyone have spark advance data for Piper camshafts? Spridgets 1
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
S TR2/3/3A Anyone care to share their bondo applying techniques Triumph 35
DrEntropy MGB Clevis pins, anyone? MG 3
69MGC Wanted Anyone know this guy? MG Classifieds 2
B Does anyone still make or sell a quality condenser? Austin Healey 14
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
K Anyone racing a TR3? Racing 5
S General TR Can Anyone identify this TR Triumph 3
C Anyone know where to get one of these? Austin Healey 6
Grantura_MKI T-Series MG TD anyone? MG 5
HealeyRick Why Would Anyone Butcher a Healey with a V8? Austin Healey 26
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
K TR2/3/3A Anyone heard of an oil additive called 'Molyslip E" ? Triumph 5
Basil SS100 anyone? Jaguar 5
Jim_Gruber Recovering Dashboard - Anyone tried this approach? Spridgets 4
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
R General TR Anyone going to TRA in North Georgia? Triumph 0
