Clutch Master cylinder, rebuild or not.
Norton47
I know this will have lots of opinions and will depend on the quality of the bore.
This new Girling unit was installed 11 months ago, and has had the fluid flushed at 9 months.
It is now starting to drip on to my foot. This is a new Girling unit.
If inspection of the bore shows it is free of pits and or scratches gouges, dirt, etc,
Now the 100 dollar question, is there a good chance of rebuilding lasting at least as long at this new unit did?
Peoples experience's with rebuilding?
Also has anyone had better Mean Time Between Failures (MTBF) using another brand, perhaps heaven forbid an after market unit?
Should last a whole lot longer than that, even with a rebuild. Did you use Girling or DOT 5 fluid both to operate and flush it ?
I've pretty much always rebuilt my old cylinders even when I probably shouldn't. Even with significant pitting in the bore, the seals have lasted longer than 11 months of daily driving.
I rebuilt mine 2 years ago and it's still great, no leaks and operates as it should. I did think I had a leak but the cap was loose and was simply splashing fluid out on the twists and turns.
Ditto the rebuild suggestion. It takes so little time (something I have plenty of) and saves $$$ (never seem to have enough) that I always try rebuilding.
I am sure I used Castrol LMA for this and the brakes.
I am about to rebuild my clutch master in my 7.5. Should I use silicon to clean it if I am going to use it in my system? It has original now.
IMO, yes. I usually start with solvent (on the metal parts), then finish with silicone.
PS I've never seen any indication that "brake solvent" harms modern seals, but I keep it away from any seal I'm going to use, just to be safe. However I was disassembling an original MC the other day (very likely with original seals in it) and the seals were grotesquely swollen by the time I got it apart. Could have been the heat, but I'm guessing they were the old "natural rubber" seals and the solvent is what caused them to swell like that. Still haven't gotten all the black goo off my hands !
Thanks Randall. Should I buy a hone for the inside of the clutch master?
Tough call, IMO. If the bore is in good shape, I'd leave it alone. If it's pitted, then it's probably better to replace it.
That said, I ran a hone through one of the MCs I just put together for the 56 TR3, as it had some very light pitting. Replacement MCs for the 56 are visibly different than the originals, so I want to try to keep them if I can. The other one looked good enough without the hone, so I didn't touch it. The hone leaves a rougher finish, which will probably accelerate seal wear at least until the bore wears smooth again.
Clutch masters by Girling are NLS. So I'd figure I would just rebuild it.
So this isn't your TR6 you're working on ? TRF even has Girling TR6 clutch MCs on sale at the moment. GI64068827 is the .75" bore and GI64066117 the .70".
Ok, I'll bite : What's a TR 7.5 ?
If it's a wedge with a Rover motor, then GI64066614 looks to be the Girling clutch MC. Not on sale but listed as available ...
saw it on their site. Took some hunting. Already bought the rebuild kit. Will attempt that first.
I rebuilt my Spitfire brake master cylinder 3 months ago and it has been great. My clutch and brakes are all silicone DOT4 fluid now. The best part of that is we over filled the clutch master when we replaced the slave and when I got home there was fluid on the firewall shelf, I just wiped it off and the paint was still there.
I see mention of "brake solvent" here.
Through many years of rebuilding British and non-British hydraulic parts, I have always used plain old denatured alcohol (from the hardware/paint store) to clean pistons and cylinder bores. It dries residue free and doesn't harm the rubber.
Thanks for the remembrance on that fact Moseso.
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
D Clutch Master Cylinder Leak Austin Healey 20
angelfj1 Wanted '59 TR3A Clutch Master Cylinder - USED, RE-BUILDABLE, NOS Triumph Classifieds 4
angelfj1 TR2/3/3A 59 TR3A Clutch Master Cylinder Failure Triumph 19
D 1965 Alpine Clutch Master Cylinder Sunbeam (Rootes) 0
warwick-steve Final fix for clutch pipe to master cylinder leak?? Austin Healey 13
KVH TR4/4A Clutch Master Cylinder Triumph 3
warwick-steve Clutch master cylinder to fluid reservoir leak Austin Healey 5
Rob Glasgow Clutch Master Cylinder Issue Austin Healey 3
Got_All_4 TR2/3/3A Clutch issue maybe master cylinder Triumph 13
S MGB MGB clutch master cylinder MG 0
M TR6 Which clutch master cylinder for a 71 TR6? Triumph 5
John_Mc TR6 Rebuild or replace Clutch Master Cylinder? Triumph 8
MY66AH Master Cylinder Clutch Rod Spridgets 6
AngliaGT Early '74 Midget - Clutch Master Cylinder Removal Spridgets 7
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
K TR2/3/3A Clutch Master Cylinder "Stop" Bolt.... Triumph 4
R Clutch Master Cylinder Shim Austin Healey 12
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
H master cylinder brake vs mc clutch Austin Healey 14
J T-Series clutch Master cylinder or slave? MG 8
Lukens More clutch / brake master cylinder questions. Triumph 7
Henson80MGB T-Series '80 MGB Clutch Master Cylinder-rebuild or replace MG 10
dondel Clutch Fork movement & Master Cylinder Austin Healey 13
PATR8 New Clutch Master Cylinder Triumph 4
mrv8q TR2/3/3A TR3 Clutch Master Cylinder Triumph 20
T Putting the clutch master cylinder back together Triumph 13
Shinsen774 T-Series Clutch Master Cylinder - The little things can be MG 14
Y BJ8 Clutch Master Cylinder Bleeding Procedure? Austin Healey 7
M Clutch Master Cylinder Cap Spridgets 7
hondo402000 TR6 TR6 clutch master cylinder arrived[not girling] Triumph 5
TRnorwegian Changing clutch master cylinder - peace of cake? Triumph 10
T Clutch master cylinder ? Triumph 5
X T-Series Clutch Master Cylinder Cap MG 2
R T-Series 74 B clutch master cylinder MG 0
I TR6 Correct clutch master cylinder fluid for 69TR6? Triumph 5
C brake & clutch master cylinder question Austin Healey 2
G clutch master cylinder rebuild. Spridgets 0
Branson Clutch / Master Cylinder Question Spridgets 1
A Clutch Master Cylinder Line Triumph 3
J clutch master cylinder bore diameter? Triumph 1
jerrybny Clutch Master Cylinder Cap Triumph 2
jjbunn T-Series Clutch Master Cylinder - where is it?! MG 3
