Hey Jim... that was a great post! Thanks! I had a good day today. Got the E clips on with some effort, but not too bad. I was wondering.. do the smaller bore cylinders take up less space in the drum, thus providing more clearance for the back of the studs to pass by? The car had 7/8 inch bores on it, so that's what I bought. But there was clear evidence of the studs impacting the cylinders, both the rubber and the metal a bit. That was on both sides. I've installed my new ones, but I ground down a grove in the metal and the rubber of the cylinder for the studs to pass by. I'm just thinking the previous owner may have installed the wrong ones, and I've just repeated the mistake. The clearance is there, now, tho, so I think they should work.
I've installed the shoes on the passenger side, just need to finish the driver's, change out the hoses, bleed the whole thing and see what happens... might be able to get back into it tomorrow or Monday. One thing I learned today... you need to re-hook up the e brake bracket because it helps pull the rear shoe into place. Without it, it twists outward and doesn't sit right.
I was able to get everything in place, by the way, without removing the backing plate. Also, I discovered that using a C-Clamp to hold the cylinder in place against the back plate allowed me to pry on the e clip using 2 screwdrivers at the same time... eventually I managed to muscle it into place. The C clamp didn't work alone... I used a straight metal bracket as a lever between the hub and the cylinder, and then the C Clamp squeezed on the bracket and the back plate. This allowed the clamp to be positioned up and out of the way of the brake line input.
I know most of you guys have all this worked out, but I thought I'd type it up in case any other newbies stumble across this thread....
Thanks for the help! I'll keep you posted!
