Brake calipers--need to repair?
100DashSix
In the process of changing the front brake pads I came across the following step, as described in the Haynes manual: "Pull out the pads...remove the cap from the master cylinder...and press the caliper pistons right in."
As I try to push the pistons in, there is absolutely no movement--on either piston or either side of the car. Are they frozen up? Is there a trick to pushing them in so that I can fit new pads?
Advance Auto and Napa both have them for ~$65 each. I suppose it could've been worse..
Just for fun, here's a picture:
tony barnhill
Great Pumpkin - R.I.P
Block of wood should move them - if not, they're probably a little frozen.
100DashSix
And is their frozenness something best remedied by buying two new calipers? Moss seems to sell rebuild kits. The wood doesn't seem to help them move.
Put a little WD40 on them and use a 4" Clamp on the cups. I bet they will move. You might have to alternate from side side to the other. Its never failed me.
MG
100DashSix
Ah! Let me give that a try.. From the way Haynes described it I figured it'd be easy with just finger pressure--and, if not, something is wrong.
shorn
At the very least, I would be replacing the pistons with stainless steel and rebuilding the calipers. The pistons look like they have seen better days. To push them back in though, you might open the bleed screw while applying pressure to the piston.
Nunyas
When I replaced the pads on my B I used C Clamps and didn't bother with opening the bleed screw. It was a bit of a wrestle to get them all the way open, at first. I imagine opening the bleed screw would make it a bit easier.
100DashSix
The clamps worked! Thanks for the advice, as usual.
I'll put rebuilding the calipers/pistons on my to-do list, as it certainly is important.
tony barnhill
They may not come back out when they're back on the car...check 'em closely.
jlaird
I know what I would do. New ones. Should be good for another 40 years or so.
Platinum
Yup. The pistons appear to be rusted, so by stuffing them back into the bores the rust/pits WILL abrade the seals and cause potential leaking/failure. With stainless pistons and a rebuild kit apiece you can renew the front braking. If the pistons returned "home" with opening the bleed screws you've an indication that the flex hoses are swollen inside and need to be replaced as well. They're allowing application pressure and NOT allowing fluid to return to zero pressure. The rear flex line will be the same. Replace all three.
...just a word in yer ear.
jlaird
And when the good Doctor speaks we all listen.
Well mostly anyway.......... LOL
Platinum
They want my bloody ZIP CODE!!!
"90210" and a buncha "stuff"...
A set of stainless pistons and a rebuild kit apiece makes a set of calipers you can count on. Hose replacement with a set of rebuilt calipers and rear cylinders makes for a known brake system. Simple as that.
....that's all I know. "Kragen" and the rest looking to data mine over the 'net are likely to be refused the stink off'n my excretia.
Sorry to be so strident, but there are limits to what I'm willing to do just for information's sake.
100DashSix
It's strange, both of those links take me to listings that are $54.44, plus they require the old calipers. Are they really less than $35?
Platinum
Send your cores to Tiawan...
I think not.
I'll rebuild my own, thankewverrymuch.
100DashSix
Hmm, I don't know about Taiwan--the Advance Auto near me is just down the street...though maybe they'd ship calipers FROM Taiwan. Then again, China will be making the new MG in the US (crosses fingers) so I suppose we have to start trusting them sooner or later.
As for the brakes, I'm concerned about them, but again will wait until the disc rotors come tomorrow, before deciding when to rebuild or replace them.
Platinum
Cores generally go to "highest bidder"... and are recycled by the lowest common denominator. Better to do the rebuild yourself if the pistons all move in the bores.
I'll trust the Chinese when the internet functions in Bejing and Canton the same way it does in Cleveland and Peoria. And I wouldn't hold my breath waiting for that "new" MG built in the US midwest either. Turning the PRC on a dime is highly unlikely to happen... especially in "dog years".
Kimberly
As to the links I provided above, the top link lists the price of the caliper for $32.99 plus $9.99 for the core. Part number is 19444 and the manufacturer is Cardone. I have never used brake parts with the name Cardone and was looking for a little feed back.
The second link provides a list of the various manufacturers and prices of calipers for a '78 B.
I don't know if zip code has any bearing on price, the zip code I used is 94564. I have found over the years that paying more doesn't always get you a better part and that packaging can have an affect on the price.
Bruce74B
I have used Cardone brake calipers on a rear disk rebuild on a GM....one of the biggest PIA systems there ever was...but I was very pleased with the Cardone parts for the two years that I kept that car after the rebuild.
Bruce
S TR6 Need wisdom on tr6 brake calipers Triumph 6
K TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims? Triumph 5
John_Koop TR2/3/3A Front brake calipers locking up when pressing on brake. Triumph 18
TomMull TR2/3/3A The ABCs of Brake Calipers Triumph 10
G Adding a Brake Booster / Brake Calipers Austin Healey 3
T TR2/3/3A Brake Calipers Triumph 7
Ripper01 For Sale Brake Calipers w/ pads- 2 Triumph Classifieds 0
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
John Turney TR6 Brake Line to Front Calipers Triumph 4
K TR2/3/3A Brake Calipers again. Triumph 1
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
D Brake calipers rebuild Austin Healey 13
S TR6 brake calipers Triumph 4
RAC68 Dimensional Differences [brake Calipers] Austin Healey 5
6 Brake Calipers Spridgets 14
davidb AH 3000 brake calipers Austin Healey 6
middie Have I damaged my brake calipers? Spridgets 9
E brake calipers MG 0
Rut Rebuilt Brake Calipers Spridgets 31
Tabcon Front brake calipers Triumph 15
Tabcon Front Brake calipers Racing 19
R Outlaw Frt Brake Calipers MG 5
T Cleaning and painting brake calipers Triumph 7
G Rebuilding brake calipers Spridgets 13
G Rebuilding brake calipers MG 2
T TR2/3/3A Tr3 brake calipers Triumph 3
TR6oldtimer TR6 TR6 brake calipers Triumph 6
Perrymip Painting Calipers and Brake Drums Triumph 5
H TR2/3/3A Cleaning TR3 Brake Calipers Triumph 6
jjbunn Type 16P brake calipers - replacements? Triumph 13
Stewart Brake Calipers MG 2
angelfj1 Girling Brake Calipers - Resleaving with SS Restoration & Tools 4
Dadandson 1974 Midget Front Brake calipers Spridgets 4
philman Wedge TR8 / SD1 Brake calipers Triumph 9
7 Getting disk brake calipers back together Triumph 1
Ed_K Remanufactured brake calipers for sale Austin Healey 5
Tinkerman TR2/3/3A Front Brake Calipers TR3 Late Triumph 6
F two different front brake calipers... Triumph 4
T TR4/4A Early TR4 - Front Brake Calipers Triumph 2
philman Wedge rebuilding tr8 brake calipers Triumph 3
vping Brake Calipers & Wheel Cylinders MG 11
MadRiver Color of Brake Calipers and Drums? Triumph 12
Johnny AH Disk Brake Calipers Austin Healey 6
jcatnite Brake calipers Spridgets 6
S rebuilding front brake calipers Triumph 9
A TR2/3/3A TR-3 Brake Calipers Triumph 1
KenASh Etype rear brake calipers Jaguar 13
B Brake calipers Austin Healey 9
R BJ8 brake calipers Austin Healey 14
S Brake Calipers Austin Healey 9
