John_Koop
Front disc brake problem when pressing on down on brakes. The both front brake calipers lockup on rotors after applying brake while car is standing still.
Brake will only release after sits for a while. Front brakes are so thigh that I can even turn the tire with the wheel off the ground.
I am using DOT 5 silicone brake fluid and the disc brake pads have only 1000 miles on them.
Is this a caliper or a brake master cylinder cause? The rear drum brakes do not lock up.
