The Roadster Factory Recovery Fund - Friends, as you may have heard, The Roadster Factory, a respected British Car Parts business in PA, suffered a total loss in a fire on Christmas Day. Read about it, discuss or ask questions >> HERE. The Triumph Register of America is sponsoring a fund raiser to help TRF get back on their feet. If you can help, vist >> their GoFundMe page.
Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
I painted a set of calipers for a GMC Jimmy 6 years ago. They were newly remanufactured. I cleaned them wih mineral spirits and wiped them down with acetone. Used VHT Caliper paint. I let them hang for about 10 or 15 minutes then put them in the over for about 15 minutes. My oven's lowest temperature is 170 degrees. Baking seemd to allow the paint to flow and form a veru smooth shiny surface. i recently gave the truck to a nephew (after removing the dic brake, LSD rear) The paint was still just as nice as the day I painted them.
I plan to do the same on a Honda Civic this spring when I upgrade to 4 wheel discs.
Since I was rebuilding mine anyway, I split mine but left the pucks and rubber on. I taped off the little area where the O ring sits...
Threw them in the blaster and glass beaded them. Blew them out and wiped them down. Hit them with eastwood caliper paint. Reassembled with New seals/pucks/boots etc.
I usually leave the caliper assembled, plug the hose port, degrease, sandblast, then disassemble, rebuild, degrease again, and paint. I use caliper paint (grey) from Eastwood.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
