TR2/3/3A Speedometer cleaning ?
karls59tr
Bronze
Does anyone have a link to cleaning the odometer gears in the speedometer? I've heard that those gears can stick and I think that is the issue with the speedo needle sticking at 20mph.
Geo Hahn
Tony Rhodes has an excellent guide for working with the speedo (last link on this page):
https://home.comcast.net/~rhodes/1967_TR4A_Tech.html
...I think that is the issue with the speedo needle sticking at 20mph.
I believe you'll find that the needle sticking at 20 mph is completely unrelated to the any odometer issues.
The odo lube would be a little on the gears and (most importantly) in the little cup hidden on the shaft of the odo (quite a bit of disassembly needed for that one).
The needle sticking is probably the drag cup binding.
TR3driver
Great Pumpkin - R.I.P
T TR2/3/3A Instructions for cleaning & re-lubricating speedometer? Triumph 5
M TR2/3/3A HVDA Speedometer Drive Triumph 10
GeorgetheTR3 TR2/3/3A Speedometer Triumph 4
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
roscoe GPS Speedometer Austin Healey 6
J 1985 TVR 280i Speedometer Cable TVR 4
F TR4/4A Speedometer cable replacement access Triumph 0
DocDup1 MGB SpeedBox Speedometer Drive MG 0
R TR2/3/3A Speedometer Reset Triumph 26
BritBite Speedometer Right Angle Drive Austin Healey 5
roscoe GPS Speedometer Austin Healey 10
PAUL161 T-Series TD/TF speedometer gears. MG 3
AUSMHLY Speedometer Fluctuation Austin Healey 21
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
M TR6 Speedometer Triumph 2
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
P TR6 Jumpy Speedometer cable Triumph 4
PAUL161 T-Series Interesting Speedometer Scenario MG 5
John Turney Getting Speedometer out of the Case Austin Healey 6
K TR2/3/3A Speedometer needle bounce? Triumph 1
P Speedometer confusion Spridgets 1
J TR2/3/3A Speedometer Bounce with Odometer Gear Movement - Benchtop Calibration Triumph 3
RJS TR4/4A Speedometer and Angle Drive Triumph 6
T Speedometer Repair Problem Austin Healey 5
J TR2/3/3A Speedometer Works Removal Triumph 10
R TR2/3/3A Speedometer Routing Triumph 15
KVH General Tech Speedometer Not Working Triumph 5
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
K TR2/3/3A Speedometer Error Again Triumph 8
G Spitfire gps speedometer Triumph 6
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
S Speedometer Angle Drive Austin Healey 2
T Wanted WTB 100 / 4 Speedometer Austin Healey Classifieds 0
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
F How does overdrive Annulus effect speedometer Austin Healey 10
M TR4/4A Speedometer Cable Routing Triumph 7
2 TR2/3/3A Can't get zero on speedometer 60K tr3A Triumph 6
B Speedometer Cable Routing Austin Healey 9
UmmYeahOk GT6 What do I need for a speedometer fix? Triumph 16
Michael Oritt Speedometer drive issue Austin Healey 4
R TR4/4A Speedometer off 10mph Triumph 6
R BN7 Speedometer issues Austin Healey 1
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
1 MGB Speedometer and tachometer on '66 MGB are not working MG 8
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
N Wanted Speedometer or dial Km/h for BT7 Mk II - buy or trade for MPH Austin Healey Classifieds 0
K Speedometer Drive Gear Issue w/ Smitty/Delaney Tx Conversion Austin Healey 16
