TR2/3/3A cleaning wire wheels
sp53
So I bought those wire wheels from that garage firer and I am trying to clean them up. Nothing has worked very well except lacquer thinner and rages. I was hoping someone might have some ideas. I tried my pressure washer, but the soot just hung in there and the lacquer thinner softens the old paint. What I will probably end up doing is some bead blasting after the lacquer thinner cleaning. What a mess. Anyways does anyone know of a place to get those little rubber inserts where the inner tube comes through the wheel?
Popeye
Bronze
Have you tried some of that "heavy duty wheel cleaner" from the usual suspects (Griot's, Mothers, etc.)? The stuff that turns pink as it cleans. I found that stuff incredibly powerful on some naaaasty alloy wheels. You need to wait 10-15 minutes for it to work.
sail
Mine didn't do a fire but were old and after a soaking the adjusters wouldn't turn although they were pretty straight. Wire wheel on a drill, steel wool and sandpaper finished with Caliper Gray from a can leaves them looking plenty good but wish I would have ditched them and bought new wires. I just don't trust them for aggressive driving, adding up mounting and all your are committing for several years.
My first outing left a front wheel caliper leaking and ruined the paint on the wheel. Glad then they weren't new but still....
charleyf
My first set of wires came off of another car. I bead blasted and painted them. Came out looking great. BUT THEN I realized that they were loose on the hubs, which also came off of the same car. The entire set of wheels and splined hubs needed to be dumped. I replaced them all with new ones. I decided that these things wear out a lot faster than most parts on our cars. And hard driving will shorten the life even more.
Charley
Kleykamp
I had mine chemically dipped and powder coated and they look like new,even though I know they are not. I use them with tubes and have not had any problems. I don't push the car hard anyway. If I ever find a couple of thousand $s laying in the street, I'd like to get the knock off (literally) mini lite style, additional set of tires, and new splined hubs, so I could change them out for driving.
B Cleaning wire wheels Austin Healey 10
Brooklands Cleaning Painted Wire Wheels Restoration & Tools 1
CinneaghTR Polishing/Cleaning Chrome Wire Wheels? Restoration & Tools 5
R Cleaning Wire Wheels Part II Austin Healey 12
R Cleaning Wire Wheels Austin Healey 16
B Cleaning Wire Wheels Restoration & Tools 13
bighealeysource Wire wheel cleaning tips ? Austin Healey 12
AUSMHLY Cleaning wire wheel splines Austin Healey 5
A Wire Wheel Cleaning Triumph 4
bluemiata90 cleaning engine wire connectors Triumph 14
H wire wheel cleaning Restoration & Tools 10
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
S TR2/3/3A Parts cleaning. Triumph 4
P TR2/3/3A Block treatment post cleaning Triumph 17
B Electrochemical cleaning of stainless steel welds Restoration & Tools 7
B Car care/cleaning? Lotus 5
Basil Cleaning fuel injectors Restoration & Tools 4
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
L TR2/3/3A Stupid Engine cleaning question Triumph 9
F Undercarriage Cleaning Austin Healey 13
S For Sale Big Barn Cleaning Triumph Classifieds 0
T TR2/3/3A Instructions for cleaning & re-lubricating speedometer? Triumph 5
TRMark TR4/4A Cleaning Striker and Restraint Assemblies Triumph 2
H Machined Engine Block - Cleaning before assembly and paint. Not sure what to do? Spridgets 5
NutmegCT Fuel tank cleaning/restoration Restoration & Tools 47
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
SASSAMON TR2/3/3A Help Wanted In Cleaning Corrosion Off SU Carbs Triumph 20
K TR2/3/3A Cleaning the gas tank...what have I done now? Triumph 19
B TR2/3/3A Control column turn signal cleaning Triumph 8
K TR2/3/3A Cleaning a gas tank with muriatic acid.... Triumph 7
PKPoole TR2/3/3A Spring Cleaning Done Triumph 2
E TR4/4A Cleaning of alloy parts Triumph 4
GTP1960 TR2/3/3A Cleaning/degreasing timing chain Triumph 11
R TR4/4A Question about cleaning instrument faces Triumph 8
G What's Your Best Car Cleaning Tip? Restoration & Tools 0
K TR2/3/3A Speedometer cleaning ? Triumph 3
Gliderman8 General Tech Cleaning sludge/varnish from a gas tank Triumph 6
cologero_100 Cleaning the satin chrome grille on a 100/4 Austin Healey 2
M Cleaning up under the hood - just how much needs to be painted? Spridgets 2
drooartz Cleaning out the parts: gauges, lights, console Spridgets 4
drooartz Cleaning up wiring Spridgets 17
H TR4/4A 4A grille cleaning Triumph 10
simon1966 Parts cleaning? Austin Healey 6
D Finally done cleaning!!! Spridgets 2
Jim_Gruber Spring Cleaning Special - Lower Valance for Spridget off of a '68 Sprite Spridgets 10
M_and_P Spring Cleaning Spridgets 0
JPSmit Cleaning Tip Restoration & Tools 0
T Cleaning a White Interior Triumph 0
drambuie Strip cleaning frames engines and bodys Austin Healey 5
W What size taps and dies for thread cleaning ? Austin Healey 7
