Cleaning up wiring
drooartz
So my new Bugeye is really quite an original car, very little was messed with by previous owners. That said, at least one previous owner loved accessories. Radio, set of fog lights, some rear lights, air horn, etc. Built a very nice console below the dash to house the extra switches and amp meter and volt meter. Neat stuff, but that console was just where my left knee has to go. Besides, by this point many of the extras had been removed and some of the switches were broken. So it was out with the console and attendant wiring.
Had about an hour free last night so I dove in. I was reminded just how simple a Bugeye is -- there are so few stock wires that it is not all that hard to figure out which wiring is not original. Luckily the PO had run all new wiring right from the fuse box and regulator without disturbing the original wires. All that "new" wiring came out without too much trouble, and the only casualty was the turn signals -- must have knocked something loose somewhere. Just need to dig around and make sure everything is still connected properly.
Eventually I'll rewire the whole car with a new harness (I did the same with the Tunebug after I bought it) but at this point I just want to get everything working so I can get the inspection done.
Cockpit before:
Cockpit after:
Pile of removed wiring:
smaceng
Remember the turn signal light depends on a good ground through the metal dash panel. I soldered a ground wire on the lamp base just to make sure. Scott in CA
Drew, what are you doing with the lights you took off?
drooartz
drooartz
Thanks for the reminder, Scott. I yanked so many wires yesterday that I'm sure there are things loose. I'll make sure to check those grounds and run extras if necessary
Not sure yet. Undecided on if I like the look on the Bugeye. Might also wind up on the MGB. Too soon to say at this point.
drooartz
drooartz
Fixed turn signals, just a loose wire at the switch. Onward we go.
drooartz
drooartz
Spoke too soon -- checked again and no flashing. Will trace wires this weekend and make sure everything is in order.
At least now all of the non-standard wiring is gone, so there's quite a bit less to sort through.
Rut
Drew,
Looking at your dash I remembered that I have a roll of Heritage vinyl I got from Ray (Whitefrog). I'm not going to use it and you are more than welcome to it. Let me know and I'll send it out.
Rut
drooartz
drooartz
Thanks, Rut. I'll PM you with details -- I will have to redo the dash at some point to cover over the radio spot. That vinyl would come in really handy!
Rut
Drew,
Got your pm and I'll send it out today. I'm on the way to Birmingham to pick up a few things and one is a quart of DAP/Weldwood Landau top and trim adhesive. I've had rotten luck with the 3m spray products letting go and my trim shop said this stuff is the best he's ever used. Great for dashes and interior panels as well as under hood applications and you can spray, roll, or brush on.
Rut
drooartz
drooartz
Thanks, Rut.
Let us know how the DAP adhesive works. I've always used the 3M stuff, but good to know about possibly better alternatives.
AN5Sprite
Thanks, Rut.
Sorry to say it, but the dash covering is mostly loose on the Tunebug so, If that's 3M...
drooartz
drooartz
That was 3M Spray 77. I guess that's the verdict right there...
I used a 3M Vinyl adhesive for the trim on the MGB, we'll see how it holds up.
apbos
The Dap/ weld wood adhesive works great. But you still need the small clips to keep the edges down and tight.
Drew
A blanking plate with some Stopwatches mounted on it makes a good alternative to replacing all the vinyl.
Paul
JPSmit
FWIW I have never been able to get the 3M to work properly, I just rely on Contact Cement
Rut
Drew,
The vinyl is scheduled to be there Monday via usps and the cost was low...just pay it forward. I picked up the Landau top and trim contact glue at an uphostelry supply shop and its used for vinyl tops as well as trim and engine compartment applications. It's only $13.50 a quart so it will cover the dash and interior with plenty left over. I'll report back after I re-do my dash and finish my interior panels. Just for grins I've made a couple of sets of backer boards for the interior and have a few extra dashes and may do different colors.
Rut
drooartz
drooartz
Thanks, Rut! Will do on the pay-it-forward.
drooartz
drooartz
Back to the wiring, I spent some more time tonight cleaning up connections and tracing a few things, and the blinkers are working again.
The surprise find of the night is that not only do I have an original heater switch, but it works! Was messing with the switch and then turned on the key and heard this whirring sound. It's a fan! Just need to get a proper "H" knob and we'll be in business.
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
S TR2/3/3A Parts cleaning. Triumph 4
P TR2/3/3A Block treatment post cleaning Triumph 17
B Electrochemical cleaning of stainless steel welds Restoration & Tools 7
B Car care/cleaning? Lotus 5
Basil Cleaning fuel injectors Restoration & Tools 4
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
L TR2/3/3A Stupid Engine cleaning question Triumph 9
F Undercarriage Cleaning Austin Healey 13
S For Sale Big Barn Cleaning Triumph Classifieds 0
T TR2/3/3A Instructions for cleaning & re-lubricating speedometer? Triumph 5
TRMark TR4/4A Cleaning Striker and Restraint Assemblies Triumph 2
H Machined Engine Block - Cleaning before assembly and paint. Not sure what to do? Spridgets 5
NutmegCT Fuel tank cleaning/restoration Restoration & Tools 47
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
SASSAMON TR2/3/3A Help Wanted In Cleaning Corrosion Off SU Carbs Triumph 20
K TR2/3/3A Cleaning the gas tank...what have I done now? Triumph 19
B TR2/3/3A Control column turn signal cleaning Triumph 8
K TR2/3/3A Cleaning a gas tank with muriatic acid.... Triumph 7
PKPoole TR2/3/3A Spring Cleaning Done Triumph 2
E TR4/4A Cleaning of alloy parts Triumph 4
GTP1960 TR2/3/3A Cleaning/degreasing timing chain Triumph 11
S TR2/3/3A cleaning wire wheels Triumph 6
R TR4/4A Question about cleaning instrument faces Triumph 8
G What's Your Best Car Cleaning Tip? Restoration & Tools 0
K TR2/3/3A Speedometer cleaning ? Triumph 3
Gliderman8 General Tech Cleaning sludge/varnish from a gas tank Triumph 6
cologero_100 Cleaning the satin chrome grille on a 100/4 Austin Healey 2
M Cleaning up under the hood - just how much needs to be painted? Spridgets 2
drooartz Cleaning out the parts: gauges, lights, console Spridgets 4
H TR4/4A 4A grille cleaning Triumph 10
simon1966 Parts cleaning? Austin Healey 6
D Finally done cleaning!!! Spridgets 2
Jim_Gruber Spring Cleaning Special - Lower Valance for Spridget off of a '68 Sprite Spridgets 10
M_and_P Spring Cleaning Spridgets 0
JPSmit Cleaning Tip Restoration & Tools 0
T Cleaning a White Interior Triumph 0
drambuie Strip cleaning frames engines and bodys Austin Healey 5
W What size taps and dies for thread cleaning ? Austin Healey 7
Tr3aguy Chemical dipping vs media cleaning? Triumph 4
K Cleaning up exterior surface of SU's? Triumph 8
M Cleaning regulator and cutout contacts Triumph 4
R Lens Cleaning/Polishing Triumph 5
dklawson Gauge Face Coating after Cleaning? Spridgets 1
dklawson Gauge Face Coating after Cleaning? Triumph 2
L Advice for cleaning/painting 1980 rubber bumpers MG 8
S cleaning old plastic Triumph 6
JPSmit Cleaning parts tonight Spridgets 6
regularman Spent the day yesterday cleaning and painting Spridgets 9
Darrell_Walker Head cleaning Triumph 16
