Head cleaning
Darrell_Walker
I spent an hour or so cleaning parts in my improvised parts washer (tub with a gallon of kerosene and a brush). Made a big dent in the crud on my heads, but they still need more work. My planned next step is to use spray carb cleaner, but that might still take several cans. Then I got to thinking (which sometimes gets me in trouble) that maybe my pressure washer could blast them a bit cleaner. Is that a bad idea? Or should I be outsourcing this, is there a magic vat of stuff at the machine shop that they would just soak them in (these are aluminum heads)?
DougF
The engine shop did mine in their tank. Came back looking like new. Reassuring to know that the inside was as clean as the outside.
JerryVV
Darrell, the short answer is yes there is a good solution. Go to Home Depot or similar store and get a 5 gal can of Paint Thinner. That's basically what is used in parts washers. Soak them in that overnight then brush well with a parts brush. After trying many different water based products that's what I did and it worked very well in my parts washer. Cuts grease and oil well. Wear solvent resistant gloves as it will not be good to exposed skin.
Power wash after with hot water if possible and then use your air compressor and blow them dry getting all of the water out of any trapped area to prevent rusting of steel parts, assuming the heads are assembled. Oil the guides well afterwards too.
JVV
Darrell_Walker
Darrell_Walker
Thanks, Jerry. That is kind of what I was doing with the kerosene, but I don't really have enough to soak them. I should have mentioned that I do have the valves in, and I don't think the heads will need any additional work. But perhaps I will outsource this, mostly because I don't want to store 5 gallons of paint thinner (the gallon of kerosene is one I've been keeping for years, using from time to time for parts cleaning).
Brosky
Darrell,
Spend a few buck (well spent) to have a local shop knock out the freeze plugs and cook the head(s) in an acid dip tank and get them really clean.
Darrell_Walker
Darrell_Walker
I also got my head back from the machine shop today. All cleaned up. Valves were all checked and fine, and they surfaced the head as there was a little wear from the head gasket (took off 0.005"). They were not warped.
As part of replacing the head gaskets on my TR8, I'm changing out the water pump. I think was hearing it start to fail, so figured it was a good time.
Anyway, I understand that the long bolts need sealant on them, because they go into the water jacket. As I was cleaning up bolts today, I noticed that those bolts also appear to have been painted. I'm pretty sure it is paint and not a black finish, as it came off easily with the wire brush. Should I repaint
them?
I'm still waiting on a few shipments of parts, but should be able to get started on reassembly by the weekend.
Darrell_Walker
Darrell_Walker
DNK said:
naw!...
Where was the paint?
Along the threaded part of the bolt shaft (at least there there wasn't rust).
Someone on the TR8 list said it was just the sealant, but it sure looked like paint. It was black.
Darrell_Walker
Darrell_Walker
It sure didn't look like any sealant I'm familiar with, but who knows what that 3M stuff was like (or what it would look like after 30 years). So should I be putting the sealant the entire length of the bolt?
DNK
Just a bit of the threads is all I did.
What are you gonna use?
Darrell_Walker
Darrell_Walker
FYI, I just got my new water pump from Woody, and it has the proper bypass hole, no need to drill it. I don't know if this is something Woody does, or if they are now being made correctly. It wouldn't have been a big deal to drill it, but nice that I don't have to! There is a noticeable difference in the smoothness (and sound) of the new pump, so even though the old one seemed OK by itself, the new one is clearly better. I'm glad I went ahead and got the new one. Also got a box from TRF earlier this week, and one from Wedge Parts today. I now have all the parts I need to start putting it together.
DNK
What are you waiting for typing all this drivel.
Get started man!
Darrell_Walker
Darrell_Walker
Get started man!
Still need to do some parts cleaning, and spending the last day at home with my son before fall term starts at UW (taking him up tomorrow). But might need a "mental heath" day off work on Friday!
Darrell_Walker
Darrell_Walker
When using the shim steel head gasket, should I use any sealant on it (like a spray on copper sealer)?
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 5
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
K TR2/3/3A The steel head stud washers? Triumph 7
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S Spitfire Cyl head coolant hose fitting Triumph 1
B TR6 Milling the head Triumph 5
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 10
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
tahoe healey "Convertible" vs "Drop Head Coupe" Austin Healey 8
K TR2/3/3A head gasket repair wire Randall Triumph 1
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
F TR2/3/3A head light buckets Triumph 3
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
R Big Healey 100 Head Austin Healey 4
R For Sale 100 engine block w/head Austin Healey Classifieds 3
B Surprise screw head Restoration & Tools 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
B Head Re-Torque Austin Healey 8
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
KVH General Tech Head Gasket Sealant Triumph 4
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
KVH General Tech ARP Head Studs/Liner Protrusion Triumph 10
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
T TR2/3/3A Water pumps/head cooling Triumph 22
T TR2/3/3A cylinder head ,valves and springs Triumph 0
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
T TR2/3/3A tr3 head gasket Triumph 38
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
DrEntropy MGB Head gasket R&R goes on... MG 13
LAW75 Hilton Head Island Concours Austin Healey 0
