TR2/3/3A Control column turn signal cleaning
BobbyO
I have finally gotten my wiring somewhat under control and am now attempting to insure the turn signals work. The control column I'm using had been sitting for quite a while so I checked it before installing. There was no continuity for either the left or right turns and it was covered in gunk so I flushed it with brake cleaner to remove built up debris, checked it again and both worked. Now that it is installed the left turn works but there isn't continuity for the right turn. I suspect there may be contamination/corrosion on the right contact. Without taking the control head apart, is there any way to clean the contact? I have a control head that was taken apart by a PO and I really don't want to tackle that kind of mess. The control head in the car was not apart before installation so there shouldn't be any reason for a loose wire.
charleyf
As far as the contacts inside the control head, the only way is to get inside of it. It is not really all that bad of a job. But it does require one to closely observe how it comes apart and goes back together. I have worked on mine while the head is still in the car but pulled up out of the steering wheel. Possible but it just makes it a bit harder to work on.
Charley
charleyf
Yes it should. That function involves the shaft that extends out of the control head and down into the tube which the wires are enclosed in. There is a open slot in the tube and a raised ridge on the extension from the control head. These two parts fit together to make it cancel. On adjustable steering wheels the tube must be long enough to accommodate the extension if the steering wheel is in a "pulled out position".
Charley
TR-3rg
Hi,
Thanks for the response. I will add that to my winter list. Its embarrassing to ride around with a blinker on!
Roy
charleyf
Yes, I know the feeling.
one of our club members made up an award. It was a necklace with a blinking light on it. I was the first recipient. But I got to give it back to him when he was driving without his wife with him to tell him his turn signals were still on. Pay backs are great!
Charley
B
BobbyO
Triumph Standard strikes again. Or maybe Lucas. Anyway, I did not have a corrosion/cleaning problem. In wiring the turn signals from the control head in the car I referred to wire colors in the control head that had been taken apart by a PO. In an attempt to see if, perhaps, the wire for the right turn signal had broken when shoved down the stator tube I partially disassembled the control head in the car. That's when I noticed the wire at the center post of the turn signal (the one common to both the left and right turn) was different from the PO control head. Once I made the proper wiring connections, the problem went away. None of the wires on either of the control heads appeared to have been moved; all appeared original.
charleyf
Good for you. Great to hear that someone solves a problem the easy way.
Charley
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
KVH General Tech Heater control valve/cable Triumph 1
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
F Wanted TR3A control head parts (trafficator) Triumph Classifieds 4
B RHD BJ8 Throttle Control Rods Austin Healey 9
H BJ8 Heater Valve/Control Tap Austin Healey 3
71TR6 TR2/3/3A Control Head horn contact Triumph 7
Lin Another Trafficator/Control Head Question Austin Healey 10
Kurtis TR4/4A Voltage Control Module Triumph 15
C TR2/3/3A Horn Control replacement Triumph 3
M TR2/3/3A Upper Fulcrum Orientation On TR3A with Late TR4 Upper Control Arms Triumph 6
B TR2/3/3A Control Head/Stator tube orientation Triumph 8
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Control hedd fit? Triumph 1
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
K TR2/3/3A The 3 Steering Wheel "Grub Screws" and the Control Head. Triumph 2
TRMark T-Series Directional Control Relay DB10 MG 4
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
Lutz Kramer Heater Control Valve function Austin Healey 2
T TR2/3/3A Questions on TR3A steering control head refresh Triumph 34
S Heater and fan control replacement - any advice? Austin Healey 9
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
G TR2/3/3A Fitting the Control Head - Telescoping [Adjustable] Wheel Triumph 20
T Hurst Line-Lok/Roll Control/Launch Control - anyone use? Spridgets 5
edkap2002 TR6 Heater Control Valve Triumph 9
T TR4/4A Heater control valve - cant completely turn off Triumph 3
KVH TR4/4A Lower Control Arm Front Pivot Bolt Triumph 9
KVH General TR Pressing in the Lower Control Arm Bushing Triumph 6
P TR2/3/3A TR3A Steering Control Head Harness Triumph 7
R TR2/3/3A New Control head wiring - Moss purchase Triumph 1
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
B TR6 Removing the ckoke/heater control knobs Triumph 4
Tr3aguy TR2/3/3A Lower control arm question Triumph 2
RCarr BN1 Lower Control Arms Austin Healey 0
G Heater Control Valve AH BJ7 - O-Ring Placement[s] Austin Healey 2
KVH General TR Pressing in the lower/inner control arm bushings Triumph 3
L Control Box wiring 100/6 Austin Healey 13
M TR2/3/3A Two black wires on control box E where do they g0 after alternator conversion? Triumph 9
C TR2/3/3A Control Head Rebuild Help Triumph 1
Got_All_4 TR2/3/3A Control head wiring help Triumph 11
