Outlaw Frt Brake Calipers
RF Thom
Has anyone replaced the stock brake calipers with Outlaw calipers. Could you advise of product code and any related problems. Currently mine are weeping, need replacement and would consider upgrading to newer technology. Thanks Bob
billspohn
Not much point spending the money on the Outlaw product when the stock calipers are prefectly adequate.
If you want eye candy, I guess I can see it, but if you want to stop any better that isn't the way to do it. The stock calipers (in good working condition, obviously) are more than capable of locking the wheels. To stop any faster you need to address the interface betweeb road and tire - in other words save the money on fancy calipers and spend it on better more modern tires.
Platinum
:lol:
PERFECT response, IMO, Bill!! A bigger CONTACT PATCH is the real improvement. :thumbsup:
R
RF Thom
Thanks guys, you have confirmed my quick research. OEM calipers have 54mm pistons whereas aftermarket units only go to 48mm so for a given brake pedal pressure less related braking effectiveness. My calipers are weeping and in need of a rebuild/replace so I guess I now know which direction I'm going. Thanks again Bob
Grantura_MKI
Just fit SS cups on your factory units and fit new seals. Tyres will also help you with grip. +1.
Cheers,
D.
JPSmit
Bob, they are an easy rebuild - do split the calipers though - makes it much easier. if you want to PM me your email, I can send you the Grassroots Motorsports article on brake caliper rebuilding - the article is about their Midget but the used MGB calipers.
kyreb1862 Weber 38/38 Outlaw Question MG 10
K TR6 Rule of thumb for frt suspension shims Triumph 6
P Moss differential and frt susp strengthening kit Triumph 9
D BN2 FRT. SUSP. Austin Healey 2
G Upgrading BN1 frt brakes Austin Healey 7
GB1 Progress GB Frt End Spridgets 6
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
bighealeysource Brake Master Cylinder Austin Healey 27
S TR2/3/3A Lockheed brake system Triumph 7
