I put the pistons back into the calipers for my 1958 TR3A, covered the open faces with duct tape (Red Green is also a Canadian) and had the bodies sandblasted, then sprayed with acid etch, primer and 2-pack black paint. The painter did all my lower parts and frame with Dupont Imron truck and aircraft paint. 18 years later and they still look like new and clean up in seconds. Others have done them in red - or grey paint to look like cast iron. I never lost points in a concours because they are painted glossy black.
BTW, In 1990 I re-installed those original pistons with new seals for the calipers. The OD of the pistons had a few rusty spots where the plating seemed to have flaked off. That was after 80,000 m iles from new. I filled the system with silicone fluid when I was doing the restoration in 1990 and those pistons have never been an issue during the last 18 summers of driving another 100,000 miles. The silicone fluid in the system acts as a lubricant and I have never had them seize, get tight or develop any more rust.
