Battery Fuse Protection
RAC68
Hi All,
Although I have installed a fair number of in-line fuses to protect almost every internal circuit, I am reconsidering the installation a battery terminal fuse, installed in most modern cars, to protect against a catastrophic short in the direct battery circuit (battery and its main line power lead). Although the fuses installed in most modern vehicles rang from 150 amps to as high as 400 amps, I would expect a much lower amp fuse would be sufficient for my Healey. Since the main purpose is to protect against a catastrophic short, the fuse range I am considering is within the range of 80 amps to 100 amps at maximum.
The installation of a battery terminal fuse would require changing the positive post clamp to one with a upward stud/post for connection to the selected fuse block along with the installation of a ring terminal end on the cable.
Your thoughts and suggestions as to fuse amperage and implementation of changes would be appreciated,
Ray(64BJ8P1)
OR
Keoke
HI Ray :
The add stud items will allow the convert, However , You should use your Max cold starter current for the minimum fuse , circuit breaker amperage rating I think.
John Turney
IIRC, most 'modern' autos use fusible links for the battery cable. They are 2 wire sizes smaller than the cable they are supposed to protect. I would not want a large melting wire under my vinyl battery cover, however.
The fuse rating should be the based on the starting current. Has anyone measured the Healey starting current? I recall we've discussed it.
RAC68
RAC68
Hi All,
Steve, I have a top poste battery in my Healey and this setup will fit nicely on top of my battery. The fuse block would sit on top of the clamp stud and the cable with the ring end would be secured on the fuse block stud.
Keoke, That was my initial thought but could not find the starter's drawn CCA and have no instrument to measure actual. According to the manual, the starter has a lock current draw of 430 to 450 amps @ 7.0v-7.4v which, I assume, means its full torque operating draw. Translating to CCA (defined as the number of amps that a 12-volt battery can deliver for 30 seconds while maintaining a voltage of at least 7.2 volts at a temperature of 0 Fahrenheit), I would expect that the number of fused amps @ 12v would be less but how much less is an unanswered question. I appreciate that when considering CCA when buying a battery is very appropriate so should be considered when selecting a fuse for the battery, however, would we need a 450+ fuse to allow for sufficient amperage for the starter operation under all conditions? If so, we will need quite a substantial fuse... and I do hope you will tell me a direct translation is a wrong conclusion.
John, I believe we did discuss it with respect to selecting a battery but never came up with a CCA for the original starter.
Ray(64BJ8P1)
Keoke
Ray:
Maybe you can rent or borrow a clamp on amp meter and measure your starters current I did not add any margin we will see.
RAC68
RAC68
Hi All,
Keoke, good idea. Measuring my starter requirement would give me a practical number in line with how and when I would use the car. With the studded fuse holder, cable ring end and post clamp with stud, I can always bypass the fuse by moving the cable directly to the clamp.
I am beginning to think fusing the battery with the amperage draw or CCA as a fuse selection parameter is not practical although doable. This would be more acceptible if a Gear Reduction Starter were used as I have heard they require half the CCA of the standard starter. When thinking further, I realized that the CCA may not be a requirement when considering reviewing the definition of CCA with reflection on how we use our Healeys. I have no intention of driving my Healey when it is 0 Farenhite. Also, cranking for 30 seconds is far longer then it usually takes my car to start. Although I am not sure what amperage the original starter draws on a nice spring day to turn with sufficient torque and speed sufficiently to start my engine, I don't believe it is close to 450 amps the manual states as lock current draw.
Thoughts,
Ray(64BJ8P1)
Keoke
Ray CCA , is not the technical definition we are talking abut here , it is the starters current from cold that it draws starting your engine.
John Turney
Ray:
Clamp on ammeters only work with AC. You will need a known small resistance, usually supplied by a shunt, but if you know the battery cable wire size and length (either positive or negative cable), you look up the Ohms per foot, measure the voltage drop over that length of cable and calculate the current flow.
steveg
The fuse is on the battery to protect the cable - assuming that's the total length battery to switch to starter solenoid.
Isn't it a matter of the cable gauge and total length with a factor of, say, 1.25 to protect the cable.
Isn't that going to be like 500 amps? Is there such a fuse?
Keoke
Naw John:Both current clamps and clamp meters read AC or AC/DC current with no need for circuit disconnection. Even, Ebay or Amazon got em.
Keoke
The fuse is on the battery to protect the cable - assuming that's the total length battery to switch to starter solenoid.Isn't it a matter of the cable gauge and total length with a factor of, say, 1.25 to protect the cable.Isn't that going to be like 500 amps? Is there such a fuse?
NO Steve:The fuse is being initiated to protect the battery from a total fault in the load.We must be very careful how we size this fuse. Done improperly the cable you refer to can become the fuse that protects " 500 " amp fuse
John Turney
Yes, there are AC/DC clamp on ammeters that will read DC current - but you have to get one that uses Hall effect sensors. Most clamp on meters don't, they use the clamp as a transformer core. Those meters rely on separate probes.
vette
Ray, the starters locked rotor amperage is the amps you would need to be considerate of. That is the designed max that the starter would draw in the worse case scenario. But an old starter could draw even more. Many motor protective fuses or circuit breakers can be derated somewhat because of the time that a motor is at a locked rotor state. Meaning that if all is working correctly the rotor starts to turn immediately and the ampere draw deminishes instantly. The derating would be in relation to the Locked Rotor Current. The high initial current is sustained by use of slow blow fuses or because of the number of cycles of current it takes a breaker to sense the overload. Of coarse DC doesn't have cycles but you get the idea.
Having said all of this as Steve has mentioned any overcurrent protection installed at the battery is only protecting against a possible fault in the cable between the battery and the solenoid. If the battery itself dead shorts it will either blow up spectacularly or it will just go poof and die. If the battery itself dead shorts it will have no effect on the rest of the car. If there are shorts in the wires contiguous to the solenoid, they are so small in comparison that they themselves will act like fuses and just burn open. In my opinion the only protection you can provide for the cable between the battery and the solenoid is to make it as big and as strong as possible. Using such cables as are in race cars or drag cars is an immediate solution.
John Turney
When we had this discussion a while back, I recall the primary failure concern was the battery cable running along the bottom of the frame becoming damaged and shorting to the frame (ground, or earth in Brit-speak). I seem to recall reading that the factory rally cars ran the battery cable above the frame.
Keoke
I agree John.
Similarly if the cable is routed above the frame this significantly reduces its proness to failure.
We call this method of fault protection Isolation and it depends heavily upon the mechanical aspects of the design.
Novamonte
If you dimension the fuse to cope with the amps drawn by the starter motor you will end up with a mighty big fuse that will allow enough current to pass to melt most of the wiring in the loom if there is a short somewhere after the starter motor. I would instead take the starter motor out of the equation and put much smaller fuses on the cable(s) feeding the rest of the electrical system. I don't have the AH wiring diagram available right now, but I believe that there are one or two cables attached to the post on the starter solenoid to which the cable from the battery is connected that feed the loom.
Novamonte
I found this on Youtube: https://www.youtube.com/watch?v=d2nPHWNoDSA. A modern four-pot seems to draw around 100 amps, so I figure that it may be around 150 or so on a Healey. If voltage drops to 10 volts that would equate 1500 watts or around 2 hp, which seems reasonable. But again, if you put a, say, 200 amp fuse on the battery that would only protect the cable from the battery to the starter. If there is a short somewhere else in the system the cable would probably melt before the fuse blows.
steveg
I had found information online that stated that a small or medium gasoline engine would draw up to 400 amps when started cold. 60 - 200 when warm.
So our 8 - 10 ft cables have to be able to handle that for a short time. A fuse would have to not blow during cranking.
Lets say we ran over a rock which scraped the cable and caused a dead short to the frame. The fuse at the battery would then blow. No fire.
Would it not have to be approximately 500 amps?
K TR2/3/3A Old school battery shut off switch....... Triumph 3
tahoe healey Battery Chargers vs. Maintainers Austin Healey 25
Bayless What size battery for my '67 Sprite? Spridgets 5
Sopwith_Camel battery drain Jaguar 35
Popeye General TR Battery Tray - yes or no? Triumph 11
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B T-Series Battery replacement mgtd MG 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
tahoe healey Battery Lifespan Austin Healey 8
EWD TR6 Battery charge loss Triumph 25
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
D Battery Minders Austin Healey 3
R MGB BATTERY DRAIN MG 7
D TR2/3/3A Battery Box drain Triumph 9
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
steveg Battery Cable Specs Austin Healey 33
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
GeorgeC Painting the Battery Austin Healey 0
GeorgeC OK to paint battery? Spridgets 9
D Battery connections Spridgets 0
A Wedge Won't fire without jumper from coil to battery Triumph 6
69MGC MGC Putting a 12v battery in the trunk MG 10
T How do you cover your battery in the boot? Austin Healey 5
S TR2/3/3A Need New Battery for TR3A Triumph 9
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
D New Battery Needed for BJ8 Austin Healey 9
HealeyRick Vented Battery Austin Healey 6
sparkydave 1500 battery cable colors Spridgets 1
G BN6 Battery location Austin Healey 7
L TR2/3/3A helmet style battery terminals Triumph 7
MGBGM1977 MGB AGM M/C battery MG 15
TRMark TR4/4A Miata Battery Triumph 6
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
wangdango BJ8 inner battery hold down? Austin Healey 4
JimTR4 TR4/4A Battery recommendation Triumph 11
3798j Fastronix Battery Compression Ends Restoration & Tools 4
M battery helmet stuck on post help Austin Healey 8
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
NutmegCT Whacko battery[s] Restoration & Tools 7
NutmegCT battery post connectors Restoration & Tools 6
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
NutmegCT Solar battery maintainer? Restoration & Tools 9
S TR2/3/3A Replacement Battery Triumph 5
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
S Battery - BJ8 Austin Healey 8
D Battery Tray Size Austin Healey 1
RAC68 Battery Powerline Protection Austin Healey 40
Patrick67BJ8 Battery Tenders Austin Healey 36
