I found this on Youtube: https://www.youtube.com/watch?v=d2nPHWNoDSA. A modern four-pot seems to draw around 100 amps, so I figure that it may be around 150 or so on a Healey. If voltage drops to 10 volts that would equate 1500 watts or around 2 hp, which seems reasonable. But again, if you put a, say, 200 amp fuse on the battery that would only protect the cable from the battery to the starter. If there is a short somewhere else in the system the cable would probably melt before the fuse blows.
Am arguing the only purpose of Ray's proposed fuse is to protect the cable between the battery and the solenoid against a dead short to the frame.
The rest of the car is relatively easily handled by the various fuses for the circuits. It would be relatively easy to add a fuse between the solenoid and brown wire that supplies the car if one was worried about that well-protected wire.
Thinking about this, the size of the fuse would be subject to experimentation. If one picked a size and it didn't blow during cranking, it would certainly blow in the case of a dead short to the frame.
Some fusible links - the biggest is 100 amps. If one installed this and it didn't blow, we'd be good to go:
