Axle flange
Jake
Anyone know if the MGC and MGB axle flanges are the same? I have a C axle and want to swap it into my V8 MGB, but need to know if I will have to change the rear flange on my driveshaft to mate up or if I can swap out the MGC flange on the axle for an MGB one.
Thanks.
tony barnhill
Great Pumpkin - R.I.P
I think that, with the exception of the 3rd member & hubs, the MGB & MGC rear axles are the same....driveshafts are different though
tony barnhill
No, flanges are the same - the metal of the tube was thicker.
E BE axle flange hub screws Spridgets 7
I rear axle to differential flange bolt grade? Triumph 8
6 rear axle flange bolts Triumph 4
B MGA Where to Buy, What to Buy? Axle Nut MG 9
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
S TR2/3/3A old 4 bolt axle set up Triumph 12
S TR2/3/3A old 4 bolt axle differential. Triumph 11
KVH General Tech Rear Brakes and Solid Axle Triumph 2
A Wanted Girling Axle for TR2 Triumph Classifieds 5
R BJ7 Rear Axle Maintenance Austin Healey 5
SNClocks Bugeye axle limit straps Spridgets 5
A Rear Axle Oil Seal Austin Healey 4
Lin Bugeye Axle Hub & Bearings Austin Healey 1
P MGB Tube axle wear MG 3
W Rear Axle Hub Seal Austin Healey 8
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
drooartz Rebuilding rear axle Spridgets 19
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
CJD TR2/3/3A Lockheed Axle Triumph 8
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
S Axle Shaft Installation Difficulty - Help Sought Spridgets 8
J TR6 Differential / Rear Axle Triumph 1
Tr3aguy TR2/3/3A Rear Axle Rebuild Triumph 3
G Trans Axle Parts Lotus 20
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
T Axle spline lengths Spridgets 0
BN6_2197 Rear Axle rearing up Austin Healey 12
K Rear Axle Breathers Austin Healey 17
S Axle leak at backing plate Austin Healey 26
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
D Wanted TR4A Live axle frame Triumph Classifieds 0
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
S Rear axle - small leak .....? Austin Healey 7
T TR2/3/3A Will cable ties hold rear axle rubber buffer securely? Triumph 7
S Gearbox and axle serial numbers Austin Healey 7
P MGB Noisy Rear Axle / Differential MG 1
R Rear Axle Restoration Austin Healey 6
Rut TR4/4A 67 TR4a irs to live axle Triumph 18
Lin Rear Axle Hub Nuts Austin Healey 3
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
C Size of axle bearing nut Austin Healey 11
warwick-steve Oil for rear axle? Austin Healey 3
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
