racer_x
I am in the process of resealing the rust prone tank in my TR8. Originally I was going to have it boiled out as TDSkip had suggested offline. After speaking with a radiator shop, he said it wasn't worth it and if it is rusted I was going to end of with a bunch of holes.
Instead, what i did was place a recipe of chains, nuts and bolts and a container of steel beebes into the tank. I sealed up the fuel pump hole and sender hole with duct tape and took it to work where we have a shaker table used to test packaging.
The shaker table was incredibly loud but did an awesome job removing the rust and varnish on the inside of the tank. It produced some small pin holes, but not very many (maybe 7).
So now I am in the process of ordering an etching acid and tank seal. Has anyone had experience with any of the companies out there?
Anyone have any advice on the process?
I imagine I am going to take some of duct tape and seal the holes up, then rotate the tank around until the liquid has solidified.
