Deleted member 8987
Well, today the tach went to zero.
Usually you have to rap the glass with your knuckle, but this quit while driving.
So, I checked for tach generator output.
Nothing.
Ohmmeter checked the generator and tach head, seemingly normal (similar readings on both).
Looking at the breakdowns, I figured the drive plate or tab on the end of the generator.
So, I pulled the generator (more fun).
The tab on the end appeared to be locked.
Oh-oh.
LOTS of effort with a pair of pliers and it did move.
Checked the depth of the drive plate in the head, compared to the generator, odd, seems like the tab MISSED the drive plate.
Grabbed the tab with same pliers and pulled, it popped out, rotated normally with the "cogging" of the fields.
Popped the back off, took out the stator, and pushed the bronze oillite bearing out with my thumb.
Ooops.
Cleaned the housing and the bushing, Lock-Tited it in, lube, re-assembled the generator, re-installed, tach works as before!
Let's see....two drops of Lock-Tite, and a bead of clear silicone sealer....what, fifty cents in parts and that's a push?
Nothing.
Oh-oh.
Ooops.
