alum flywheels experience
chrpark
anyone had experience with the aluminum flywheel (fidanza?)
i'd be installing on a 948cc 9cmotor set up for fast street including a judson supercharger...
i dont buy the baloney HP estimates in the ebay ad (+15HP?!) but would still think the lighter weight brings some benefit...
i believe some of the shops also sell alum flywheels and i am not sure if thy are same manufacturer.
thanks
Westfield_XI
IMHO there is no HP change. But the lower inertia will allow the motor to rev faster and that may be expressed as an HP change on a rolling road type dyno due to the way it measures power. But an engine dyno connected to the crankshaft will show no increase.
spritenut
I have had one for years, I think it was money well spent.
Sure, no "horsepower" gain but the engine will rev up alot quicker and when the engine revs quicker, the car gets up to speed quicker.
It is seat of the pants performance you can feel.
bgbassplyr
mightymidget said:
Torque lost?
Torgue is grunt
Changing to an aluminum flywheel will not cause loss of torque, only loss of inertia.
Torque is a function of the engines cam timing-lift-duration, plus spark timing, carb setting, etc.
Flywheel weight when starting to turn or slowing is a function of inertia. The heavier it is, the longer it takes to spin up or down.
On the 948, if you can find one, I think I would pass, the poor little 948 needs all the help it can get, to get going and a lighter flywheel for it is not the hot ticket for road use. Add to that no one really makes a decent 948 aluminum flywheel for the 948, Tilton quit making them years ago, and Fidanza unit has the wrong offset on it.
Bottom line you can mostly rule it out for the 948, due to that fact they are not available.
jlaird
IMHO your best bet is to have the stock flywheel lightened.
J Alum shroud alloy Austin Healey 7
G Alum Radiators Triumph 2
jackq Found a nice alum B valve cover MG 1
A TR2/3/3A Triumph TR-3, 4, and 6 alum. oil pan Triumph 3
healeyboz alum flywheel Spridgets 6
toysrrus E-Type Consoles: Alum. or Vinyl? Jaguar 3
rulle7 Quick Qustion/Alum. dash Spridgets 15
C Welding Alum. shroud cracks, and hole repair Austin Healey 7
Bob Claffie Cockpit Alum Austin Healey 4
A alum. primer Austin Healey 18
JFS Bolting to alum block Triumph 5
KLUTZ New Alum. Carb. mounts installed Triumph 0
Y MGB Pitfalls and cans of worms regarding MGB flywheels MG 12
K TR2/3/3A Flywheels again...... Triumph 11
Rut Flywheels Spridgets 7
B 948 flywheels? Spridgets 8
T TR4/4A TR4 & 4A, Flywheels and Clutches Oh My... Triumph 6
T TR4/4A TR3 and TR4a flywheels interchangeable? Triumph 5
NardisCNC Aluminum Flywheels - worth the money?? Spridgets 16
TR6oldtimer TR6 TR250-TR6 flywheels Triumph 6
fad64b TR2/3/3A TR3 starters and flywheels HVDA Triumph 11
healeyboz Flywheels Spridgets 4
Bret Fidanza Aluminum Flywheels MG 38
C 18 gb flywheels MG 1
JPSmit Interesting experience yesterday Restoration & Tools 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
Sarastro TR4/4A Exasperating experience with voltage regulators Triumph 3
J Experience with High Ratio Steering Box? Austin Healey 15
L TR2/3/3A Looking for the Voice of Experience Triumph 23
M Anyone Have Experience with Moto Build Ashley or Speedwell Repro Hardtops? Spridgets 2
Rob Glasgow Austin Healey Experience Site Austin Healey 8
D Experience with Mallory twin point distributor. Austin Healey 5
PatGalvin TR2/3/3A Rear Sway Bar experience Triumph 5
Jim_Gruber Experience with Minilight not Minilite Wheels Spridgets 2
J TR2/3/3A British Car Forum and The Triumph Experience? Triumph 18
T TR2/3/3A Experience with repro cylinderhead Triumph 5
R MGA Experience buying an MGA from a US Vendor - Vendor Review forum? MG 8
F Any Experience with BendPak MD-6XP Scissor Lift? Austin Healey 8
max71 MGB Anyone have experience with the Pertronix Ignitor III? MG 11
G TR6 Your experience with Luminition ignition Triumph 3
GTP1960 TR2/3/3A the value of experience when setting timing on a modified engine Triumph 33
drooartz Looks like I'll get some more engine removal experience Spridgets 31
KVH TR4/4A Dangerous Experience to Share Triumph 4
R Windscreen Installation Experience Austin Healey 3
W Anyone had experience with this vendor? Spridgets 8
B experience with tire size changes? Other British Cars 2
B Experience with Cometic Head Gasket for BN2? Austin Healey 8
bighealeysource Great experience with classic car insurer Austin Healey 5
T TR2/3/3A Any experience with Nexen SB02 tires on TR3A? Triumph 5
K Anyone experience a broken crosshaft pin.... Triumph 6
