When bolting ancillaries to a TR8's aluminum block, should anti-seize be used to prevent corrosion of dissimilar metals or should loctite be used to prevent bolts from loosening because of low torque requirements? Or should the bolts simply be put in clean? My inclination is to go with the anti-seize. /ubbthreads/images/graemlins/confused.gif
