Alternator Conversion - Generator Control Box?
dklawson
This is a slightly different question about alternator conversions.
I converted my GT6 to a Delco alternator several years ago. I've had no problems with what I did... but I didn't do anything special with the wiring to keep things looking original either.
On the Mini I gutted the Lucas generator control box and used it as a junction box for the wiring so I didn't have to cut or splice the harness. This give the engine bay a much more original look. It also has the advantage that it's much easier to put the car back to a stock configuration.
I have a friend who wants me to help him do an alternator conversion and I want it to be neater than what I did on my Triumph. I haven't found any articles talking about gutting an old Triumph control box and using it as a junction for the wiring.
After studying the diagram for my car it looks like I should gut the control box and run heavy shunt wires between the two heavy gauge spade lug terminals. Similarly, it looks like I should install a shunt between the two small gauge spade lugs... leaving the ground/earth lug disconnected. (All this with the coils and such removed from the old, dead control box). It should then be a matter of leaving the wires in their original positions on the control box and plugging the generator wires into the back of the alternator (heavy wire to a big lug, small wire to the field coil spade lug). Optionally, we can run an extra heavy gauge wire from the remaining alternator output terminal to the hot side of the starter solenoid.
Am I missing anything? Has any Triumph owner used a dead, gutted control box as a junction box or is the something only done with the BMC cars... and if not... why not?
dklawson
dklawson
Funny you should mention that...
While googling on this subject, Dan's name came up on several links. Sadly, a number of the links that sounded promising were on the VTR site which now wants you to login with a user name and password. I'm not a member.
Dave Russell emailed me some advice off the board and suggested some other areas to search. Thanks Dave.
JFS
Bronze
I converted my TR3 to a one wire alternator a number of years ago and gutted the control box and used it as a junction box. I don't remember where I put my wiring notes -- but it shouldn't be too difficult to see what is connected to what after I get the car out from storage. I do remember running a new, heavier single wire to the alternator and not using the original generator wire.
G
When I converted my TR6 to a 63 amp Delco-style alternator, I chose to bypass all the original TR wiring (even though I have a new harness) and chose instead to use a new, heavy-duty double positive lead to the battery, the smaller of which (8-gauge wire) I used to accept the current from the alternator, the larger wire went to the starter with the TR muli-spade connector inline. The end result, though not original, sure as heck is sensible and sturdy. Spent a lot of time tidying up everything to where the wire routing looks professional. An aside, the higher amp alternator sure makes all my lights work better, plus all the other gizmos I have hanging off my system.
I know that TR indeed ran a Delco-brand alternator on some model Triumphs as original, not sure of the amperage though.
Bill
I Bugeye generator/alternator conversion question Spridgets 7
R TR6 Generator to alternator conversion Triumph 6
I generator/alternator conversion Spridgets 25
Starbuck Generator/alternator conversion...what's involved? MG 4
losmorob Info on Generator to Alternator conversion Spridgets 5
6 generator-alternator conversion Spridgets 2
B 100-4 generator to alternator conversion? Austin Healey 6
R MGA Generator to Alternator Conversion MGA MG 7
VelodromeRacer Generator to alternator conversion Austin Healey 4
G TR4/4A TR4A generator to alternator conversion Triumph 2
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
PAUL161 T-Series Dynamator Alternator conversion. MG 23
S Stag Lucas 18ACR alternator conversion Triumph 5
longbridgehealey Alternator conversion and tach Austin Healey 9
BoyRacer Wiring question for alternator conversion Austin Healey 3
M TR2/3/3A Water Pump Belt After Alternator Conversion Triumph 6
G TR2/3/3A Wiring ammeter with the British Wiring alternator conversion. Triumph 13
Got_All_4 TR2/3/3A Just Discovered These Alternator Conversion Anyone Do One Triumph 15
D BT7 conversion to alternator Austin Healey 14
J Conversion to alternator Austin Healey 15
TR3driver TR2/3/3A Mea Culpa - TR3 Alternator conversion Triumph 1
M TR2/3/3A Ford Alternator Conversion Problems Triumph 10
roscoe BN1/BN2 Alternator Conversion Austin Healey 7
M TR2/3/3A Two black wires on control box E where do they g0 after alternator conversion? Triumph 9
D BN1 alternator conversion Austin Healey 4
mgedit TR2/3/3A Alternator Conversion TR3 Triumph 7
V alternator conversion Spridgets 10
GTP1960 TR2/3/3A Moss alternator & narrow belt conversion questions Triumph 22
J Alternator Conversion - Gutting the RB340 Regulator What must be done? Austin Healey 16
thechileman TR4/4A Alternator Conversion complete- '64 TR4 Triumph 1
T TR2/3/3A TR3A Alternator conversion Triumph 15
richie Alternator conversion Triumph 16
J Moss / Lucas Alternator Conversion..... Spridgets 17
jhorton3 GM Alternator Conversion Spridgets 21
bugedd Alternator Conversion Spridgets 16
C Alternator Conversion ??'s Triumph 17
Patrick67BJ8 Alternator Conversion & Regulator Wiring Help Need Austin Healey 11
gubba Alternator conversion Question Triumph 25
hondo402000 Bosch alternator conversion Triumph 3
JKent one-wire alternator conversion Austin Healey 6
C Wedge TR8 alternator conversion Triumph 12
Jeepster Dynamo to alternator conversion Austin Healey 10
C Alternator conversion Austin Healey 1
N Festiva Alternator conversion!! Spridgets 3
RedTR3 Alternator Conversion Complete Triumph 4
J Alternator conversion for 71 Midget Spridgets 17
bigjones 1500 Alternator conversion woes Spridgets 21
T TR4/4A What narrow belt on alternator conversion TR4a? Triumph 7
