100-4 generator to alternator conversion?
bj8bn2
Member
Has anyone converted a 100-4 from generator to alternator? I'm looking for detailed "how-to" information. Thanks.
August
1956 100-4
1967 3000
Shealey
I have not personally done it on the 100-4, but it should very straight forward. I would use a GM one wire type. First, is your car neg ground? You'll need to fab up some brackets. If you don't have the tools to weld and drill I have an engine here under the bench. I could make brackets for you. Wiring will require a lead from the alternator to the + battery terminal and a switched exciter wire with a bulb in line like the generator wire is now.
Cottontop
There is an article for the generator-to-alternator changeover on the NTAHC web site (www.ntahc.org). It is article number 8 under "Tech Tips".
Here's a link to it = https://tinyurl.com/5ajap2
I just wrote Don to see if he has a like article for the 100-4. I'll let you know.
Tim
Michael Oritt
August--
The wiring part of the conversion is quite straightforward as others say. The only special challenge a 100 presents is whether you can find an alternator with a pulley that will accept the wider fan belt.
I use a Prestolite/Leece-Neville 75 amp alternator that came with a "Universal" two-piece shiv that can be shimmed out with washers to take the wide belt. I have had this alternator on my 100 for about eight years after briefly trying a Lucas alternator that I got from "The Cape" along with a mounting bracket that bolts onto the block in place of the original bracket. The diode holder in the Lucas unit melted within a few hours of installation--However the Cape bracket was nicely made out of cast aluminum and I used that from which to hang the Prestolite.
A nice feature of the Prestolite is that the regulator is externally mounted and if it goes off you don't have to change out the entire unit.
Let me know if you need pictures.
B
bj8bn2
Member
Thanks Michael and everyone for your response. I went to e-bay looking for the recommended Delco alternator and I found a seller that specializes in generator to alternator conversions. This is the link https://stores.ebay.com/Kansas-Select-Products I can get a 63 amp alternator and bracket, a wider puller and the wiring harness for about $100 plus shipping. The bracket is not great looking but it will do for now. I'm going to give this a try. I'll submit a post when I get it done (and it's working!).
Again, thanks for the advise.
August
healeynut
August -
Hey, that's a great little website with some good stuff in it. Let me know how it installs, and if that little bracket doohickey is any good. I've been looking for a good way to install an AC & gen set to my A90 Atlantic.
S 1956 100 Generator Austin Healey 7
Z 100 Wide Belt Generator Pulley Austin Healey 5
M AH 100-6 Generator- SMOKE! Austin Healey 7
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
A 100/6 BN4 Restoration Austin Healey 4
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 7
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
prb51 100-6 Drum Brakes Austin Healey 9
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
K 100-6 Interior Austin Healey 4
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
R 100 Motor and Gearbox Available Austin Healey 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
T 100-Six Clutch Recommendations Austin Healey 5
