TR6 175cd strombergs
sundown
Hey everybody starting to get warmer time to rebuild.Big question what is the copper pipe on the rear carb under the air cleaner flange for? I capped it, I capped the vacuum advance on the dizzy, capped the thermostatic valves on the radiator. Thanks for any answers
poolboy
If you had a thermostatic vacuum switch in the top radiator hose, you did not have a Vacuum Advance.
The last distributors that had a Vacuum Advance were the ones on the 1971 engines.
I don't know of any nipples under the carb's air box mounting flange.
If there is a nipple on the bottom side of a carb, it would be closer to the carbs' intake manifold mounting flange.
If that's the actual location, it would be the source of the Vacuum that activates the Vacuum Retard module on the distributor.
sundown
sundown
Thanks thats it since I capped off the vacuum retard on the distributor I should also cap off the carb one Willthis mess anything up with the performance of the carbs?
poolboy
Actually, there's no need to cap the nipple on the distributor..it's just a hole now. But the nipple on the carb is sucking air which disrupts the fuel air mixture entering the combustion chamber, so that's the nipple (the source of the vacuum) that needs capping.
As far as affecting performance by deactivating the retard, not in a negative way will it affect performance.
Let's say the retard was working and your engine was idling at 900 rpms, then you came along and pulled the vacuum tube off the nipple on the bottom of the carb, and immediately put a plug on that nipple. What you would notice is an increase in the rpms of about 200.
That's because your engine became more efficient with the resultant advance in ignition timing.
But that effect would only be noticeable when the rpms are below approx. 1100 rpms.
Above that, there would not normally be enough vacuum to activate the retard.
The exception to that statement is the amount of vacuum during engine braking, such as shifting to a lower gear in order to slow the car down, but performance per se should not be a factor under those conditions.
Is that long winded enough answer to your question ?
Tim Tucker TR4/4A Stromberg 175CD (c.1825) rich above idle Triumph 12
E MGB MGB ZS Carb 175CD MG 4
Zimmycobra TR4/4A Who's right - float height on ZS 175CD? Triumph 5
sundown 175cd stromberg carbs Triumph 4
A Zenith 175CD carbs Triumph 9
R Stromberg adjustment screw tight 175CD Triumph 10
M Help with Tuning Stromberg 175CD Carbs in Houston Triumph 37
M zenith stromberg 175cd Triumph 0
H stromberg carbs....150cd and 175cd...diffrence? Other British Cars 7
T Stromberg 175CD Triumph 35
bmurphy7369 Stromberg Confusion, 175cd vs. 175cd-2 and engine fires... Jaguar 5
Bret Zenith Stromberg 175CD vs. SU HIF44? MG 13
SherpaPilot TR6 Strombergs with poor idle Triumph 11
K TR4/4A Strombergs again..... Triumph 7
K TR4/4A Strombergs...wont idle unless choke pulled out? Triumph 7
B For Sale 175 CD Strombergs Triumph Classifieds 0
K TR4/4A Strombergs Triumph 6
sundown TR6 1973 TR6 strombergs Triumph 3
K TR4/4A Replcing the Strombergs with SU's on a 4A.... Triumph 6
B Strombergs Run Rich Triumph 12
K TR4/4A TR4A SU's replacing Strombergs....Linkage issues? Triumph 10
TR4 Settting up the Choke on Strombergs? Triumph 15
K TR4/4A TR4A Strombergs or SU's? Triumph 3
G Lesson learned replacing Strombergs with SU HS6s Triumph 17
glemon Making Strombergs Richer Triumph 22
SherpaPilot Strombergs Running Lean Triumph 18
TRnorwegian Reinstalling the old Strombergs Triumph 2
Phil73 Lotus and Strombergs Triumph 6
Got_All_4 Mixture adjustment on Strombergs Triumph 9
B performance increase from triple strombergs?? Triumph 33
B TR6 TR6 Strombergs Triumph 3
GT6_Mark UK Market Strombergs - Prefix Numbers Triumph 0
mabbott TR6 Rebuilder of TR6 Strombergs? Triumph 11
D Triple Strombergs Triumph 15
G Should I be lubricating my Strombergs? Triumph 8
pcanonge Strombergs? Jaguar 11
S Triple Strombergs or Triple Webers Triumph 15
RobT Strombergs and...Bosoms? Triumph 2
Jayrz Goodbye Strombergs!! Lotus 1
Stinky Velocity Stack for Strombergs? Triumph 13
Hegg Strombergs Flooding and won't start Triumph 12
