Settting up the Choke on Strombergs?
TR4
I had my 64 Strombergs professionally rebuilt and am in the process of tuning them. I feel that I have the air balanced and fuel set very close to perfect. The motor runs very well and the plugs show good color. I am experiencing difficulty in setting the choke though. When the motor is cold, I pull out the choke and it will start right up but will sputter and chug until the motor warms up and I push the choke back in. Then all is well and it runs great. Can someone tell me how to properly set up the choke? The place that rebuilt the carbs tells me the mixture is too rich and the choke needs to be set up leaner. With Stromberg carbs, I'm not sure how to do that. This is for a TR4 with dual carbs.
sd80mac7204
Phil, Try only pulling your choke out part way and see if you engine responds better.
poolboy
With the engine stone cold and low ambient temp., pulling the choke knob all the way out should start the engine at about 11-1200 rpms.
If it's set in that range, once the engine starts to gradually warm up, gradually push the choke knob into the dash accordingly.
Depending on the ambient temperature you may not need full choke..like sd said
TR4
TR4
I have tried to use less choke but still get sputtering and chugging. The RPM's do not rise at all with the choke pulled. The motor barely keeps running but when it warms up, it will run smooth.
DNK
Doesn't sound like the choke is working correctly
Have you observed the choke lever as it has been pulled?
Is there any change when you pull the choke
sd80mac7204
Will the engine start with no choke?
TR4
TR4
Engine will not start without pulling the choke out.
When I pull the choke knob, the choke spindles rotate as designed and the throttle is increased.
TR3driver
Great Pumpkin - R.I.P
That would be the "fast idle" adjustment. For some reason it's not covered in the workshop manual I have handy; but on the front carb (I think) there should be a screw sticking out of the throttle lever, which rides on a cam when the choke is pulled. Loosen the locknut and turn the screw out to raise the fast idle rpm. IIRC, it should be set to supply around 1200 rpm with the engine warm and the choke pulled only enough to start the fast idle without moving the starter bar in the carb throat (first notch).
It's also normal to need more choke for easy starting, and then back it off in stages as the engine warms up. I prefer to err on the lean side (use the least choke that will keep the engine running), because excess fuel can wash away the oil film in the cylinder and promote rapid piston ring wear.
Also check that both starter bars are moving together. Sometimes those folded metal clamps can slip without being obviously loose. I don't know if the TR4 is the same, but on the TR3 the bolts in those clamps take a BA wrench rather than SAE (or a small crescent wrench will work).
Geo Hahn
TR3driver said:
...IIRC, it should be set to supply around 1200 rpm with the engine warm and the choke pulled only enough to start the fast idle without moving the starter bar in the carb throat (first notch)...
On mine the starter bar moves first and immediately -- I see no way to avoid this as the shaft of the starter bar has the cam which operate the throttle shaft.
The screw described can be adjusted to slightly delay the butterfly movement though on mine I've got it set to move the throttle almost immediately.
I seem to recall there is a spec for clearance between the screw and cam though with worn parts and vagaries in engines it may be a case of 'whatever seems to work'.
TR4
TR4
My starter bar moves first and immediately as well.
Sounds like I should try to depress the gas pedal during start up to see if that will affect the rpms.
If so, then I should be able to simply adjust the screw for the fast idle cam.
DNK
Always helpful to step on the gas slightly as you pull as it takes some tension (for bettor words) off the cable
poolboy
Only when pulling the cable though. I wouldn't use the accelerator pedal again until after the engine actually starts, not during the cranking because you'll be leaning out the starting mixture if you do.
The clearance between the head of the fast idle screw and the fast idle cam is usually about 1/4--5/16 when the choke is off. But make it whatever it takes so that the throttle opens enough to make the engine idle 11-1200 when the choke knob is pulled out all the way on a cold engine..
All this assumes the choke cable is attached to the fast idle cam correctly.
TR3driver
Ok, my mistake. I was thinking of the arrangement on the later ZS carbs, which don't even have a starter bar (and lost motion in the linkage so you can get fast idle without changing the mixture).
But the idle should still be coming up.
TR4
TR4
I agree, the idle should rise. If I don't have luck with depressing the gas pedal, I believe I will try to screw in the fuel adjustment to see if leaning out the carbs has an affect.
At least I have 2 options to try this evening. Thanks for all the input. It sure helps to get a plan of action.
TR4
TR4
Reporting my efforts. I tried to work the gas pedal but that failed to help at all so I turned the fuel adjustment screws in 1 full turn each and presto, the choke works like a champ again. So it appears the carbs may indeed have been set too rich. Now, I think I'll back those adjustment screws back out until I get a balance between the choke working and the fuel flowing like it should.
glemon
I have been going through the same thing setting my TR4 Strombergs, if they all work the same, then in addition to the adjustment to the fast idle screw on the choke cam, there is also a low tension spring that works to pull the choke adjustment as you pull the choke cable, at first I thought this was just a return spring, but I believe, and it appears that the spring tension affects the relationship between throttle opening and choke opening, when I was experiencing the same problem changing from a firmer replacement spring to the old spring I had thought of as worn out helped with the balance between throttle and choke on start up and cold idle.
I also leaned out the mixture a little as you did after reading the plugs, and that helped too.
Todd78d Bugeye choke linkage Spridgets 5
Todd78d Choke Linkage Photo Austin Healey 0
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
D BT7 Choke Assembly Austin Healey 18
P MGB Zenith water choke gasket needed MG 4
D Choke Cable Length Austin Healey 0
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
L MGB 1977 MGB will only run on full choke MG 53
SherpaPilot TR6 Choke Assembly Triumph 0
M Choke Linkage Austin Healey 3
D Carb Choke Cable Austin Healey 9
M TR6 1973 TR6 - broken choke cable Triumph 6
TomMull TR2/3/3A Which choke cable Triumph 12
sparkydave Zenith auto choke coming loose Spridgets 2
T TR6 TR6 Choke Cable Lubrication Triumph 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
K TR2/3/3A Couple of choke questions Triumph 1
K Choke cable replacement Austin Healey 1
D AH 300O MK1 Choke Knob Position Austin Healey 5
R Jensen-Healey Choke? Other British Cars 1
F TR2/3/3A Choke Cable Problem Triumph 29
F Choke sticking Austin Healey 22
N Enrichener [choke] wire Austin Healey 1
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
F TR2/3/3A Choke Triumph 1
edkap2002 TR6 72 tr6 choke cable Triumph 4
Patrick67BJ8 BJ8 Choke Cables Austin Healey 5
TRMark TR4/4A Choke Cable Routing Triumph 3
S TR2/3/3A choke operation from the factory !!!! Triumph 29
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
S TR4/4A aftermarket choke cable Triumph 3
sparkydave Zenith auto choke coming loose Spridgets 3
K TR4/4A Strombergs...wont idle unless choke pulled out? Triumph 7
UmmYeahOk GT6 I Give Up! Help A Millennial Out [Carb/Choke Related] Triumph 28
M TR2/3/3A Choke Cable Detent Device Triumph 11
Rob Glasgow Choke cable turnion Austin Healey 8
TomMull TR2/3/3A Choke on new to me TR3 Triumph 16
L Choke Mechanism 100/6 Austin Healey 26
trrdster2000 TR6 Double Choke Cable Repair Triumph 0
1 TR6 Tr6 needs choke to run good Triumph 11
rjc157 bn7 electronic choke Austin Healey 0
A 1960 BT7 choke location Austin Healey 8
E T-Series MG TD choke cable MG 2
O Electric choke problem. Jaguar 0
T TR2/3/3A TR3 choke cable connection help needed Triumph 21
