TR4/4A Strombergs
Geo Hahn
Speaking of Strombergs generally - I seem to recall that some later ones had mixture adjustment made with a tool through the top. Still later came 'emissions' models that were designed never to be adjusted (though naturally there are still ways to change the mixture on those too).
Geo Hahn
In what way are the TR6 Strombergs different...
The Moss catalog drawings may give you some idea of the differences:
TR4/4A Carbs
TR250/6 Carbs
In addition to the change in how mixture is adjusted, the 'choke' mechanisms are very different. TR4 uses a 'starter bar' which lifts the piston slightly to enrichen the mixture. The TR6 uses a 'starter box' which I think uses a rotating disk with ever-increasing small holes that are exposed to allow additional fuel for cold starts.
dklawson
The Strombergs that adjust from the bottom are "CD" carbs and the later ones that adjust from above are CD2s. The CDs adjust very much like an SU with an bottom mounted movable jet. On CD2s the jet is fixed and require a special, long Allen wrench to reach down into the bottom of the dashpot to adjust the mixture needle.
trrdster2000
I've had very good luck with the CD ones on the 4/4A's and found them to be just that little quicker in reaction than the SU.
Not all will agree with that, but I was working on TR's when they came in England and they were not well received there either.
Wayne
SherpaPilot TR6 Strombergs with poor idle Triumph 11
K TR4/4A Strombergs again..... Triumph 7
K TR4/4A Strombergs...wont idle unless choke pulled out? Triumph 7
B For Sale 175 CD Strombergs Triumph Classifieds 0
sundown TR6 1973 TR6 strombergs Triumph 3
sundown TR6 175cd strombergs Triumph 4
K TR4/4A Replcing the Strombergs with SU's on a 4A.... Triumph 6
B Strombergs Run Rich Triumph 12
K TR4/4A TR4A SU's replacing Strombergs....Linkage issues? Triumph 10
TR4 Settting up the Choke on Strombergs? Triumph 15
K TR4/4A TR4A Strombergs or SU's? Triumph 3
G Lesson learned replacing Strombergs with SU HS6s Triumph 17
glemon Making Strombergs Richer Triumph 22
SherpaPilot Strombergs Running Lean Triumph 18
TRnorwegian Reinstalling the old Strombergs Triumph 2
Phil73 Lotus and Strombergs Triumph 6
Got_All_4 Mixture adjustment on Strombergs Triumph 9
B performance increase from triple strombergs?? Triumph 33
B TR6 TR6 Strombergs Triumph 3
GT6_Mark UK Market Strombergs - Prefix Numbers Triumph 0
mabbott TR6 Rebuilder of TR6 Strombergs? Triumph 11
D Triple Strombergs Triumph 15
G Should I be lubricating my Strombergs? Triumph 8
pcanonge Strombergs? Jaguar 11
S Triple Strombergs or Triple Webers Triumph 15
RobT Strombergs and...Bosoms? Triumph 2
Jayrz Goodbye Strombergs!! Lotus 1
Stinky Velocity Stack for Strombergs? Triumph 13
Hegg Strombergs Flooding and won't start Triumph 12
