mightymidget
My MG has a 1275 engine. I have a summit water temp mechanical gauge I want to install. The proper mounting place seems to be in the radiator. When I borrowed the motor from the Bugeye I stripped the existing housing fitting out of radiator trying to remove bulb. I found a pipe plug and carefully tapped the existing hole and installed a plug. It is all doped up and I am scared to try and remove. Making my radiator beyond use.
My 1098 had a bung hole in the themostate housing, but Moss doesn't show one. Are they available anywhere, and will they work on a 1275? if not where can installed the water tempature gauge bulb.
I broke the 1098 housing during removal
