TR6 TR6 V8 Conversion
G
Dear All,
Am looking for serious advice on the feasability of converting my 73 TR6 to a V8. Do any of you know of websites that go into detail of the mechanics of such. Thinking along the lines of a Buick (Rover) light weight engine. Would it hook up to my Triumph gearbox? Also want to keep the rearend stock. Am running a Sachs clutch off a Rover V8 - any adapter plates out there for a direct hookup? The simpler, the better, the old K.I.S.S. adage. My current engine is a total, quality rebuild with trip ZS carbs, rollers, etc. Beautiful! (and for sale) Just not enough raw power! Mid-life crisis!!
Dr. Bill
VitSport6
Hi Dr Bill.
Here is a great site!
https://britishv8.org/swaps/examples.htm
Looks like ALLLlll sorts of good ideas!
Have fun
MDCanaday
Oh No Dr Bill Oh No!!! actually since it goes into an mgb without much fuss a rover V8 isnt too bad an idea. I suggest the 5 spd 7/8 tranny is the way to go here,not the stock unit. Saw a BGT the other day that had AC that really worked, so you could also if you wanted to. The stock diff will take a lot of power if its in good shape.....
Good luck !!
MD(mad dog)
Sherlock
... Or try an old fashioned Ford V8 (302 or 351 I believe), a guy here in Ontario has done and told me that it fit in almost perfectly and actually has better balance in there than the original engine.
He took the engine out of a 1979 Ford LTD, did some performance modifications and dropped it in. The car body doesn't look any different (even the hood - er bonnet to you Brits - doesn't need to be changed). Apparently a number of people in the States have done roughly the same thing. Unfortunately I don't know of a website to look up.
[ 06-17-2003: Message edited by: Sherlock ]</p>
UltimateQuestion
Check out the latest "Newspaper" sale ad from TRF. There is an article about some guys from the Long Island Triumph Association who are building a V8 TR6. While they were at it, they also widened the car by six inches!
Gary Pope
I would go for a Ford 302 or Chevy 350.
Parts galore, cheap and performance oriented.
Plenty of nice add ons that will make the engine look sharp.
Some of the bulkhead needs to be cut away to get the bellhousing situated. It is something I have thought about and may do it one day, the prospect of good idle performance and no timing issues ever again are appealing .. not to mention a roaring V8 roadster.
martx-5
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by UltimateQuestion:
<hr></blockquote>
I'm a member of the
Long Island Triumph Association, and, yes we are widening a TR-6 by 6 inches, and are going to put in a Rover Aluminium V-8. The front end will be lighter then with the iron 6 cylinder. The frame of the donor car was too rotted to be widened, so we welded up a new frame from 3 inch square tubing. There a pics and info on the web site. Click on the link above, and on the left side you'll see the TR6+6 link.
78Z
I'd go for the Ford FI 302 V8 and T5 transmission for a 80s Mustang. They weight almost the same as the TR6 engine (the Chevy 350 weighs a bit more and is slightly larger). The TR6 doesn't really need the lightweight Rover V8.
cjsteak
Dr. Bill,
What all have you done to your motor performance wise? Has it been balanced? How about the cam? I'm looking for a really hot motor for my tr6.
How much are you asking?
Thanks
P.S. I'm going to add the triple su carbs this weekend, how do yours work? Was the performance noticeably improved?
G
Dear cjsteak,
My engine is a total rebuild with turned crank, bored 20 over with new AE pistons, stock-style cam, Roadster Factory rebuilt head, roller rockers, triple ZS (GoodParts), stock ignition with Sport coil. Didn't balance, blueprint, polish or anything. Runs really well. Probably not for sell at this time because the V8 conversion would cause a divorce, if you know what I mean. The GoodParts intake with Gary Martin triple Strombergs is really sweet, and extremely easy to tune and keep tuned. Had dual DGV Webers and hated them. Also went through 5 electronic ignitions. Buncha crap. Points and condensors are the only way to fly. Keep a TR engine as close to stock as possible is highly recommended; make it bigger and stonger but don't change it!
Dr. Bill
TRED
I drove my 69 TR6 today for the first time since 1987.
The V8 conversion I did wasn't easy and most of my original TR6 is long gone. Only the outer shell and the front suspension remain. Whats it like to try and put 500+ HP to the ground in a TR6?
Scary is a word that comes to mind.
Hard to get the smile off my face.
Gary Pope
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Dr. Bill:
Dear cjsteak,
Dr. Bill
<hr></blockquote>
Can you elaborate on the electronic ignition problems, are you talking about the Pertronix ignitor's ?
I have a fairly severe breakdown in my ignition system and I suspect the ignitor unit. I had noticed the wires inside the distrib have been damaged by the rotor. I put insulating tape around the bare parts .. but not sure if its working right.
G
Gary,
No, I had the Crane (Allison) 700 series (2) and the 3000 series (3), all of which worked for a short while and then absolutely shut down. Now, I have a new British Wiring harness, correctly installed. I repeat, the points and condensor are the only way to fly. Adjustable, stable, plenty fire and cheap!!
Dr. Bill
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
I TR6 TR6 EFI Conversion Triumph 19
B TR6 Moss TR6 Vacuum Advance Conversion question Triumph 8
S TR6 TR6 speedo to electronic conversion anyone? Triumph 15
Coyote1 TR6 Weber 45 MCHH conversion for TR6 Triumph 15
rjc157 TR6 tr6 su conversion Triumph 2
B TR6 TR6 Weber 45 MCHH Conversion Kit Triumph 10
bobh TR6 New TR6 Transmission Conversion Triumph 3
rjc157 TR6 tr6 su conversion Triumph 8
H TR6 TR6 HS6 Conversion Triumph 6
YYCDave TR6 TR6 Rear Shock Conversion & Tire Size Triumph 2
DanNagy TR6 TR6 Weber Carb Conversion Triumph 11
B TR6 TR6 alternator conversion Triumph 20
mgbmedic MGB MGB or TR6 -- 280Z 5 Speed Conversion MG 2
T TR6 Thoughts on HS6 conversion for TR6? Triumph 11
C TR6 TR6 Shock Conversion Kits Triumph 13
LeeMcKee TR6 TR6 Five Speed Conversion? Triumph 5
A TR6 TR6 heater fan conversion?? Triumph 5
A TR6 FREE, Manual Overdrive Shifter conversion [tr6] Triumph 1
kodanja TR6 TR6 Ford type 9 conversion Triumph 0
A TR6 TR6- Group buy of Moss axle and hub conversion?,or Triumph 4
A TR6 tr6 5speed conversion??? Triumph 14
G TR6 TR6 seat conversion Triumph 10
V TR6 TR6 Fiberglass bumper conversion? Triumph 1
milemarker60 TR6 TR6 Roadster Conversion? Triumph 10
v8triumph TR6 Rover V8 Conversion TR4 - TR6 chassis Triumph 8
Webb Sledge TR6 TR6 Carb to Lucas Injection Conversion Triumph 4
B TR6 TR6 Electronic Ignition Conversion Triumph 10
bigbadbluetr6 TR6 tr6 tranny conversion? Triumph 11
B TR6 Tr6 4 speed to 5 speed conversion? Triumph 13
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
