Engine paint
Rob Glasgow
Al, just to confuse your search a little more, there are at least two different version of the big Healey engine paint. One is a little more yellow like the Moss Motors version and one is a little more blue/grey like the Bill Hirsch version. I used the enamel from Hirsch since it matched the original color. But I have to admit, I prefer the Moss version. Either way, only weirdo Healey buffs would know the difference.....
in the first photo the generator is Moss green and the overdrive is the original paint. The last two photos show the completed motor in the Hirsch green.
B
barnman
Al
You could just buy it from one of the usual suspects.
:cheers:
Thanks Bob, just have done. I try to support local suppliers but it seems a minefield!
Anyway , job done and its got to be better than the red it was painted....if you want to see the car in its early state see Fast and Loud season 4 episode 12... the Blue BJ8.
Thats mine now...will try and post a stream of pics to follow.
B
barnman
Love those pics and will try to get close to the later one...looks about correct.
Have ordered from the usual suppliers though try to support local people , hence the enquiry.
Thanks for your help.
Al
John Turney
Recommendation: do an engine primer under the paint. Then clear coat after paint. I did just paint years ago and it looks ok, but when I had the rocker cover off, I repainted it and then clear coated. A real improvement.
steveg
Clausager refers to the color as "steel dust grey" - I always wondered why. The OD looks like it could be that color.
Healey Nut
You can buy POR15 engine enamel in the correct Healey colour off flea bay.
I just got a small can for 25$ its a pint . Havent looked in the can or tried it yet .if I dont like it I will just paint over it .
aero3113
Healey Nut, I’m not 100% sure but I think the POR “Healey green” is a dark green and not the metallic lighter green.
Keoke
[/QUOTE]
I've never been able to warm up to a product named "Paint Over Rust" - POR.
NO Reid: That not what it mean:
It means "Paint on Rust," Made especially for healey.:glee:
B
barnman
Healey Nut ,I've just tried it from Frost on my gearbox.
It looks like army surplus camouflage paint so I will be going over the area I've done with something more appropriate.
Both tins going back!
Healey Nut
I will have to crack the can I have and take a look . If its the wrong colour it will just become a good primer I guess .
Healey Nut
Cracked the can and its not even close . Its that Morris green colour that they used on the A35/Cambridge/Somerset engines .
Oh well it will make a good base coat primer .
HealeyRick
It's also the color they used on Sprites, so technically they're not lying when they calll it "Austin-Healey Green"
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
H Machined Engine Block - Cleaning before assembly and paint. Not sure what to do? Spridgets 5
Marvin Gruber BJ8 engine paint color. Austin Healey 25
KVH TR4/4A Engine Paint Triumph 3
B Engine Paint Austin Healey 13
jlaird Engine paint Spridgets 16
N Engine paint??? Spridgets 11
H engine paint question Austin Healey 19
Magyar T-Series MGTF Dark Red Engine Paint MG 7
K engine paint Austin Healey 5
S engine paint help Austin Healey 2
TomMull Engine Paint Triumph 6
A question about media blasting and engine paint. Austin Healey 14
BOBBYR Por-15 engine paint Austin Healey 7
M Engine Paint Austin Healey 4
J Engine component paint Austin Healey 3
J Body/Engine Paint codes....? Austin Healey 6
PAUL161 T-Series Engine Paint for a TF? MG 10
chrpark engine paint Spridgets 16
T TR4/4A Paint color for engine bay fuel lines TR4a Triumph 4
M Poor Dupli-Color engine enamel paint results Triumph 13
lbc_newbie Engine paint color....conundrum Spridgets 35
B Engine Prep for Paint Austin Healey 2
M Engine Block Paint Triumph 16
N 1964 sprite engine paint color Spridgets 3
Trevor Jessie Engine Paint Spridgets 8
S Mini engine paint color and pics needed British Motor Corp 9
T 1955 100-4 Engine Paint Austin Healey 8
R Engine paint Triumph 19
JeffS looking for PPG engine green paint code.... HELP! Austin Healey 9
M 1275 Engine Paint Schemes? Spridgets 7
B Question on paint typs for engine parts? Restoration & Tools 16
glemon Moss Engine Paint Application Austin Healey 5
B "Original" Healey engine paint? Austin Healey 10
R BN1 engine paint Austin Healey 7
tateboys Why paint engine compartment black MG 33
C Engine Compartment Paint - Do-Over!! Triumph 6
C I finished paint the engine compartment tonight!!! Triumph 7
S Frame and Engine Compartment Paint Austin Healey 7
F Engine Paint...powder coating or just high temp? Triumph 7
MadRiver Engine color and paint? Triumph 15
A Spitfire 78 Spit - Correct engine/suspension paint? Triumph 4
W Morris Green Engine Paint Code Spridgets 4
jlaird Per previous discussion on engine paint Spridgets 0
S TR2/3/3A $10 in spray paint vs. TR3's engine bay Triumph 10
M Engine Bay and Rattle Can Paint Triumph 9
KLUTZ Brush paint for engine bay? Triumph 15
fmichaels engine paint Spridgets 10
Tullamore Engine Paint Spridgets 8
