Spitfire 78 Spit - Correct engine/suspension paint?
AustinJim
I've been looking for the correct paint to use when restoring this car. As I take parts off to replace or repair them I'd like to clean and repaint them before reinstalling. I can't seem to find any paint that has the correct amount of gloss to match what's left of the original. The high temp paint I've found so far is too flat and the gloss is too glossy. I'm currently swapping the transmission and would like to repaint the case and bellhousing but I'm also looking for correct paint for all of the under hood stuff. Any suggestions?
Thanks!
billspit
At one time Ditzler (now PPG) made a black primer that was an excellent chassis/suspension paint. Not sure how glossy it was though. Maybe someone else remembers. I just used PPG's Deltron paint with Delthane hardener.
myspitfire
I wouldn't paint the transmission case its aluminum for one reason it keeps the internals cool,aluminum disipates heat.If you paint it it locks in the internal heat. /ubbthreads/images/graemlins/nonono.gif
Ken
A
AustinJim
On mine, the main housing and bell housing are definately cast iron and painted. The tailpiece looks like it's magnesium or something similar and it's not painted.
boeingpilot For Sale Parting out '75 and '76 Spit 1500s Triumph Classifieds 0
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
lilifer_13 Spitfire New alternator doesn't fit - '78 Spit Triumph 2
M Spitfire Triumph spit flange/hub removal Triumph 13
D Spitfire 1980 spit.. 34000 miles unbelievable Triumph 5
dklawson Spitfire Bleeding Herald Brakes [similar to Spit] Triumph 9
G For Sale Round-tail Spit-6 Project car with OD for Sale [Cambria CA] Triumph Classifieds 0
tomshobby Spitfire head size of damper pulley bolt on 78 Spit? Triumph 2
D Spitfire 1975 Spit resurrection Triumph 4
trrdster2000 GT6 Finally got a photo of some of our work on the Spit 6 Triumph 2
mgedit TR2/3/3A Coolant spit out of overflow Triumph 20
B Spitfire Parting out 67 Spit Mk3 Triumph 1
D Spitfire MkI Spit questions Triumph 9
AEW Spitfire vintage racer replica on Spit running gear. Triumph 4
T Spitfire Free early Spit in Boise Triumph 1
zedvictor1 Spitfire different diff for Spit 1500 with overdrive? Triumph 1
T Spitfire Grease slinger position on a Spit 1500 axle Triumph 7
glemon Spitfire Craigslist Spit Triumph 2
G Spitfire Anyone ever see a Spit look like this one? Triumph 5
tr6nitjulius Stag TR3*4*6*7*8*Spit*GT6*Stag=20 [pics] Triumph 0
H Post-War Other Spit 1500 Engine in a Herald 1200 Triumph 1
D Spitfire '65 Spit window regulator installation tips needed Triumph 0
This14u Spitfire Pic of Spit A-Pillar Details Triumph 3
D Spitfire MKII cam in a MKII '65 Spit - pros and cons Triumph 2
D '65 Spit heater control valve Restoration & Tools 1
TonyPanchot Spitfire 72 Spit 1500 Key Light Triumph 2
TonyPanchot Spitfire Spit Windscreen trim Triumph 3
6 Spitfire Tire bumps wheel well on spit mk3 Triumph 5
K Spitfire Door striker 63 Spit Triumph 1
tr6nitjulius Spitfire TR3*3 TR4*2 TR6*7 Spit*2 GT6*1 Others*2 Triumph 5
G Spitfire Bought a Spit today, a bit bummed out Triumph 12
G Spitfire Spit Hardtop $50! Triumph 4
G Spitfire Weight diff b/w Spit 4 and 6? Triumph 3
O Spitfire Spit 1500 Thrust Washers? Triumph 13
This14u Spitfire Clutch Slave Access on Late Spit Triumph 0
doates Spitfire Why Doesn't My Spit Sit Level Triumph 8
B Spitfire Advice on Muffler for 69 Spit Triumph 5
B Spitfire big bearing snap rings on Spit single rail Triumph 0
Dudly Spitfire steering wheel for 79 spit Triumph 1
Dudly Spitfire Blowing fuses in my 79 spit Triumph 10
B Spitfire Aftermarket synchros 1500 Spit single rail Triumph 2
M_Pied_Lourd Spitfire Low Mileage Spit Triumph 3
B Spitfire 1500 SPIT OD ELECTRICAL Triumph 1
Reh Spitfire GT6 rear shock to spit mount Triumph 3
doates Spitfire Spit was running great Triumph 17
G Spitfire Anyome here running a single DCOE on a Spit? Triumph 0
doates Spitfire Spit Does Not Want To Stop Triumph 12
K Spitfire Spit rear spring... Triumph 4
A Spitfire Can I remove the nut on the front of a Spit diff? Triumph 4
A Spitfire Free 1500cc Spit Engine in SF area Triumph 0
