Spitfire Blowing fuses in my 79 spit
Dudly
Hello all, hope everyone is well on this first day of June.
Problem starts with my sister in-law allowing her two beautiful girls (they really are lovely) sit in my spit and monkey around. No worries, I’m not an ogre, and besides they are just so cute sitting in it.
Anyhow ever since then I keep blowing the fuse that's in charge of the horn and high beams, coming off the turn signal indicator.
Replace the fuse, hit the high beams a couple of times and pop.
Any suggestions?
Thanks
TR3driver
Great Pumpkin - R.I.P
Do the high beams work OK if you turn them on through the regular headlight switch, instead of the "flash to pass" feature? If so, I would suspect a problem with the switch itself. It's kind of fragile, and very tempting to young hands.
When I was about 3, I managed to release the handbrake and wreck the family car, or so I'm told. All I can remember is the moment when the open car door hit the wall ...
Dudly
Dudly
Thanks Randall, I did sort of the same thing with my grandma's corvair ( really miss that car).
It seemed to go while doing both. Interestingly i discovered a little box of Lucas fuses and installed one of them, has not blown since.
You don't suppose it was some sort of quick vs slow blow issue?
I'm not looking forward to tearing apart the switch and all.
Rhodyspit75
Did one of them by chance push in the cigar lighter? It's on the same fuse and if you had too small a fuse in when you turned on the high beams you may blow it.
Scott_Hower
Also check the chrome "fold down" map light. Always tempting to play with and sometimes wont shut off.
TR3driver
Could be. I've never seen a "slow blow" Lucas fuse, but that doesn't mean they don't exist.
What size fuse are you using? And are you running stock sealed beam headlights?
Dudly
Dudly
You may have hit it on the head. Was using aftermarket 12A, when what was in there was a Luca #35 15A. After finding that little box of Lucas fuses it hasn't done it since. ( this could just be a case of user error).
Though I am interested in the issue with the lighter as mentioned by Rhody. I may just pull the plug on that anyhow as I haven't had a need for one of those in about 5 years.
RE: the map light, I don't have one, must not have been an option in 79, though I wish it was.
TR3driver
I don't have my manual handy, but a Lucas 15 amp (or aftermarket 12) both seem awfully small. As noted, there are a lot of things on that circuit, and just the headlights will be drawing roughly 10 amps.
Dudly
Dudly
Ok well I feel like a dolt, upon further inspection it appears that they are Lucas 35 amp fuses.
Perhaps this was my problem all along.
TR3driver
That would explain it. Don't forget that the Lucas rating system is different, making those roughly 17.5 amp fuses. Some Lucas "35 amp" fuses even have a piece of paper inside that says 17.5, but not all of them do.
Dudly
Dudly
Well I am happy to report that so far so good. It appears this was my problem all along.
Picked up some more fuses, from my main man Scott at Team Triumph, and they are just as you describe Randall, little slip of paper, Lucas #35. Prince of Darkness fortune cookies?
Ok poor joke. Anyway thanks for the advise my man!
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
W Fuses Blowing Austin Healey 11
Jim_Gruber Blowing 15A Fuses as soon as I apply the brakes Spridgets 6
S TR6 TR6 blowing fuses Triumph 4
Brosky Heater blower blowing fuses Triumph 6
Sopwith_Camel MGB-GT blowing fuzes MG 14
ckeithjordan TR2/3/3A Blowing a Fuse Triumph 30
edkap2002 TR6 1972 Blowing fuse fed by white wire Triumph 6
StagByTriumph General TR TRA in Blowing Rock NC 2018 Triumph 1
TRclassic3 TR2/3/3A Help with fuel gauge blowing fuse Triumph 6
C new engine - oil pressure blowing filter seal Austin Healey 12
Q TR2/3/3A TR3A Blowing Bulbs!! Triumph 5
johnrip Wedge TR7 side marker Light issue fuse keeps blowing Triumph 2
wkilleffer 1993 Cutlass convertible blowing a fuse Other Cars 7
T Blowing oil....???? MG 20
B 74 XKE blowing white smoke. Jaguar 14
emann Horn constantly blowing Spridgets 7
drooartz Found the problem with blowing my oil filters Spridgets 27
J Problem with Head Gasket blowing more than once Triumph 10
G Spark plug's blowing bubbles. Help! MG 10
C Mind blowing XJ220S for sale in US Jaguar 0
R Bugeye fuses Spridgets 14
K TR2/3/3A Fuses Triumph 3
K TR2/3/3A 30 AMP Fuses Triumph 2
longbridgehealey In line fuses Austin Healey 25
M Fuses Austin Healey 7
M Additional Fuses Austin Healey 3
F TR2/3/3A Fuses Triumph 10
K TR2/3/3A TR3 Fuses Again Triumph 1
T TR6 Blown Fuses Triumph 1
B Fuses for 1960 BT-7 Austin Healey 3
RickB All 4 parking lights dead, fuses all good? Spridgets 6
W Glass fuses Jaguar 3
I TR6 TR6 correct fuses? Triumph 8
H Tr 3 fuses Triumph 10
C AH 100-6 Fuses/wiring...what did I do? Austin Healey 6
af3683 35A Fuses Triumph 14
M Still con-fused about fuses Triumph 22
A Midget Fuses Spridgets 7
A TR2/3/3A TR3A FUSES Triumph 4
longbridgehealey Bugeye fuses Spridgets 5
Thor lights on without any fuses- Any suggestions Spridgets 6
J Additional fuses Austin Healey 1
Paulus MGB 69 MGB fuses MG 8
D Fuses? Triumph 9
Tinkerman TR2/3/3A TR3A fuses Triumph 9
Tronch Adding Fuses Austin Healey 4
19_again Fuses in'66 B MG 12
B fuses Brit vs US Triumph 5
G Question on fuses Spridgets 9
