T-Series Engine Paint for a TF?
PAUL161
I know Duplicolor had a color, T-278 or Deep Canyon Red, seems it's about as close as you can get to the original color, but, I understand their discontinuing it. Any knowledge on this or a different manufacture? Moss engine paint supposedly fades with time, any knowledge on this also? PJ
Platinum
Krylon did that (discontinued) too. :madder:
They had one called "Harvester Red". Really close. Now it's completely different.
Grantura_MKI
I have had good luck with Moss paint. Only issue being that hot coolant will leave spots. As a rule, I purchase two cans to spray the motor and gearbox.
Cheers,
D.
PAUL161
PAUL161
David_DuBois said:
Paul - Check all the auto parts stores in your area, there may be some of the Deep Canyon Red left on their shelves. I did that a month or so ago and bought a whole stock of it.
Cheers,
Dave, did you hear anything about Duplicolor having cases of the paint in their warehouse that can be purchased only by the case? If that's true, I'll order a case. PJ
PAUL161
PAUL161
I just wrote the manufacture to see what they say. Who knows, can't hurt! PJ
JPSmit
OK, if it is called harvester red, it's tractor paint - go see what TSC has in stock.
Platinum
Yup. But it ain't th' same now. Whole diff'rent colour.
David_DuBois
Haven't heard that, at least not from the store I purchased the paint from. they had one can on their shelf and a whole bunch in their warehouse.
Cheers,
Grantura_MKI
One problem with a case purchase. Unless you plan on using all of the cans in the near future, I would pass. Over time the cans will loose their charge and will become useless.
Cheers,
D.
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
B Engine paint Austin Healey 17
H Machined Engine Block - Cleaning before assembly and paint. Not sure what to do? Spridgets 5
Marvin Gruber BJ8 engine paint color. Austin Healey 25
KVH TR4/4A Engine Paint Triumph 3
B Engine Paint Austin Healey 13
jlaird Engine paint Spridgets 16
N Engine paint??? Spridgets 11
H engine paint question Austin Healey 19
Magyar T-Series MGTF Dark Red Engine Paint MG 7
K engine paint Austin Healey 5
S engine paint help Austin Healey 2
TomMull Engine Paint Triumph 6
A question about media blasting and engine paint. Austin Healey 14
BOBBYR Por-15 engine paint Austin Healey 7
M Engine Paint Austin Healey 4
J Engine component paint Austin Healey 3
J Body/Engine Paint codes....? Austin Healey 6
chrpark engine paint Spridgets 16
T TR4/4A Paint color for engine bay fuel lines TR4a Triumph 4
M Poor Dupli-Color engine enamel paint results Triumph 13
lbc_newbie Engine paint color....conundrum Spridgets 35
B Engine Prep for Paint Austin Healey 2
M Engine Block Paint Triumph 16
N 1964 sprite engine paint color Spridgets 3
Trevor Jessie Engine Paint Spridgets 8
S Mini engine paint color and pics needed British Motor Corp 9
T 1955 100-4 Engine Paint Austin Healey 8
R Engine paint Triumph 19
JeffS looking for PPG engine green paint code.... HELP! Austin Healey 9
M 1275 Engine Paint Schemes? Spridgets 7
B Question on paint typs for engine parts? Restoration & Tools 16
glemon Moss Engine Paint Application Austin Healey 5
B "Original" Healey engine paint? Austin Healey 10
R BN1 engine paint Austin Healey 7
tateboys Why paint engine compartment black MG 33
C Engine Compartment Paint - Do-Over!! Triumph 6
C I finished paint the engine compartment tonight!!! Triumph 7
S Frame and Engine Compartment Paint Austin Healey 7
F Engine Paint...powder coating or just high temp? Triumph 7
MadRiver Engine color and paint? Triumph 15
A Spitfire 78 Spit - Correct engine/suspension paint? Triumph 4
W Morris Green Engine Paint Code Spridgets 4
jlaird Per previous discussion on engine paint Spridgets 0
S TR2/3/3A $10 in spray paint vs. TR3's engine bay Triumph 10
M Engine Bay and Rattle Can Paint Triumph 9
KLUTZ Brush paint for engine bay? Triumph 15
fmichaels engine paint Spridgets 10
Tullamore Engine Paint Spridgets 8
