Wanted Engine stand adapter
LDRITZ
I'm looking to buy, borrow, or steal? an adapter to mount a 948 Bugeye engine to my harbor "'fright" engine stand. Or maybe someone has pans to build such adapter?
Thanks!
Grantura_MKI
It should adjust down to pick up fitting spots on the block.
Be sure that you are near to where the center of the mass will be when built...center point should be above the crank shaft.
Joe Schlosser
Generally, BMC a series engines are bolted onto the stand on the left side of the engine. There are two threaded bosses on the block just above the oil inlet that are use to support generator angle bar.
I am not sure what parts come with a harbor freight stand but my stand came with a plate and some bars. The bars bolt to the block on the threaded bosses and then onto the plate that goes onto the stand.
It looks backward form the "conventional" system of bolting into the transmission bell housing bolts in that the bard go inward from the flat plate as opposed to outward.
I do not have a picture as I have gifted my stand to a friend for his Nissan engine but there are pictures in Vizzards book on tuning the A series engine.
Mounting on the side gives you free access to install most everything except the oil filter and line.
I have built 10 plus engines with this method of attachment.
PS, you should move this post to the Spridget board
LarryK
Adapters are needed for most engines. I have always kept mounts from various engine assembly tools as evry engine isn't totally compatible with the stands. I can put a domestic big block on a stand, but have to use different bolts and angles to mount a Jag 6 or a Triumph 4. Just have to play with them. I have a 1000 lb stand that a Ford 460 fits fine but I have to reinforce for a Jag 6 because the 6 sticks out 2 cylinders farther and tilts the stand.
Hap Waldrop GT6 Triumph 6 cylinder side engine stand adapter Triumph 13
B Engine Stand Adapter Spridgets 2
J For Sale Hoist and engine stand Triumph Classifieds 0
M Engine Stand for 3000 Motor Austin Healey 7
A Making an A-series engine stand adaptor fitting Spridgets 2
J Mounting 3000 engine to stand Austin Healey 7
M Engine Stand - What Bolts Recommended for 948 Spridgets 3
P TR2/3/3A Wetliner in a engine stand, how? Triumph 4
A Engine stand rotisserie plans Austin Healey 12
KVH TR4/4A Using the Engine Stand Triumph 3
2billydavies TR2/3/3A what bolts should i use to mount engine on an engine stand? Triumph 13
T Engine stand Austin Healey 2
V Engine Stand XK150 What works? Jaguar 5
T Engine test stand Austin Healey 8
J Engine stand adaptor specs or diagram? Spridgets 7
TulsaFred Engine test run stand Spridgets 10
S T-Series How do we mount a TD engine on an engine stand? MG 7
J Engine Test Stand Restoration & Tools 7
B engine stand Austin Healey 15
T Engine stand 101 Triumph 14
T Engine stand recommendations Triumph 14
lbc_newbie Engine stand bolt sizes Spridgets 1
Gray_Cat Engine Stand Rotisserie Spridgets 4
J TR6 best way to mount the TR6 on an engine stand? Triumph 3
J Harbor Frieght Engine Stand? Triumph 0
J Harbor Frieght Engine Stand? Restoration & Tools 15
JPSmit Engine Stand Spridgets 0
Trevor Jessie Nice engine test stand Spridgets 7
PHerder Tequila Brad's engine stand LIVES!!! Spridgets 0
L Engine stand: how do you attach? Spridgets 12
Tinkerman TR2/3/3A How to build an engine run in stand for 60 TR3 Triumph 9
drooartz Engine stand/dolly Spridgets 20
Tinkerman TR2/3/3A Engine Stand 60 TR3 Triumph 1
weewillie engine stand Restoration & Tools 12
ChrisS KB / Engine Stand Spridgets 4
JPSmit Engine Stand Question Spridgets 26
timbn2 engine securing points to engine stand??? Austin Healey 18
C TR2/3/3A Tr3 Engine Stand Question Triumph 3
Ohiobugeye 948 cc on An Engine Stand Spridgets 17
pa297pass 6 Cylinder on an Engine Stand Triumph 4
J Engine Stand Mounting Austin Healey 7
klutterbutt 1275 on an engine stand MG 14
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
