TR4/4A Bent pushrod
chassutton
After a major engine rebuild (mostly done by professional machine shop), the engine started and ran beautifully for about 100 miles.
Suddenly things went south - diagnosis.. a bent pushrod on cylinder #2 exhaust valve.
Most obvious cause would be a stuck valve but that does not appear to be the problem. No other cause that I can think of??
Installed a new pushrod (from Moss) and, again, the engine is running great, about 100 miles so far. I'm keeping my fingers crossed, hoping it was a freak event.
However, would very much appreciate any input.
The ignition timing was quite retarded (my fault) and an old timer at a local repair shop mentioned he vaguely remembers this sometimes causing damage to a pushrod on older engines.
Again, any input very welcome.
Thanks
CJD
Anything different from stock...shaved heads, bronze guides, high-lift cam, new valve guides, nylon valve seals, etc?
Deleted member 8987
Usually a stiff guide. Often ends up with a bent valve.
Do a compression test.
Geo Hahn
Adding to that - the offending guide may not bind until high enough engine heat occurs.
As I recall, depending on the choice of material for the guides - they may need to be reamed to a specific tolerance to allow for heat.
C
chassutton
I have to assume and hope!!! the guides etc were checked for clearances. I used an established/reputable machine shop with lots of experience on old engines of all types.
I'll put on some miles/hours over the next few weeks and report back. Thanks.
Geo Hahn
Hi John.
All standard stuff. Parts from Moss.. valves, guides...
Moss sells guides in both cast iron and manganese-bronze. Which did you use?
As I recall, the clearances are different (due to differing expansion) and some (possibly the manganese-bronze) may have to be reamed to work properly.
Perhaps someone with a better memory or more recent experience can comment.
sp53
There are 2 different types of pushrod diameters out there; the 5/16 pushrod that are stock and older and maybe did it all time--- BEND. They also have 3/8 pushrods; they are beefy and do not bend; we used to talk more about it.
Pease out
steve
titanic
I was fortunate that the bronze guide seizure became apparent as soon as the engine reached operating temp after rebuild. It involved 2 exhaust valves and was caught before the push rods were damaged.
Berry
Deleted member 8987
I remember doing LBC's in shops I ran years ago...and guide sizing was a big issue. Machine shop that knows old bow-tie engines hasn't a clue on how to set up an LBC head.
We would have to search (and try) machine shops and machinists who were skilled to do the work and size guides correctly.
Then you'd get the FBN (fly-by-night) hairballs who sleeved the guides..
I remember doing heads myself where guides were just a bit loose and knurling guides, sizing...surprisingly those worked really good if cast guides.
CJD
Coming from Chevy's that amazed me too. On Chevy you can run the bronze guides very tight with no problems. The valves in the Triumph must get much hotter than the Chevy's.
Deleted member 8987
On bow-ties they are tight...but they don't shrink up when hot. Have to be tight when all they depend on is a square cut o-ring in the spring retainer for oil control.
Seen so many LBC issues like that. Usually the valve hung and hit the piston. Not sure I would be happy with removing the built-in safety of a skinny pushrod over a thick one that would not bend.
Of course, my engine of choice never bends a pushrod and cannot have piston-valve interference unless a valve head comes adrift.
And no seals, since oil runs uphill harder than down.
Alfred E. Neuman
Berry
Out of curiosity, what were the symptoms that had you shut the engine down when the valves tightened up in the guides?
titanic
The engine started to run rough as the temp increased. With the valve cover removed, I could see the valves sticking. I removed the head, disassembled it, and could see traces of bronze on the valve stems. The machine shop appologized, re-reamed the guides, and no further problems.
Berry
poolboy
The car's PO built that engine, Tom.
The cam and tappets got wiped out.
The problem must have been a combination of valve springs, cam selection, and rocker arm ratio...anyway it ran like that for 20,000 miles....
The same head, the same valve guides, the same seats, the same push rods and most of the same valves are in the current version of that engine, going on 30,000 miles.
B Bent frame rails near BE front end Spridgets 2
P Classic Tube Pre-Bent Brake Lines Austin Healey 5
PAUL161 T-Series Bent Push Rods MG 34
L TR2/3/3A Bent lower wishbone arms Triumph 6
KVH TR4/4A Bent Valves Triumph 11
M TR2/3/3A Forward Carb Jet Lever Bent Triumph 12
B Overdrive Operating valve bent Austin Healey 15
J Healey 100 -- Broken rocker and bent push rods !!! Austin Healey 7
N Spitfire Should this be bent? Triumph 4
nevets pre-bent brake lines Austin Healey 7
M Bent Frame Spridgets 3
B TR2/3/3A is this a bent tr3b frame? Triumph 7
tinman58 Bent pushrods Triumph 69
J Disc rims all bent and out of round Triumph 11
bugedd My bugeye is bent Spridgets 31
jsfbond Flange bent? Triumph 6
glemon Bent Rear Hub/Axle Triumph 2
theleisure 3 out of 4 wheels bent, looking for new used set Spridgets 11
H TR2/3/3A TR3 Accelerator Shaft -- Straight or Bent? Triumph 9
I TR6 TR6 windshield frame bent? Triumph 8
19_again coil springs are bent Triumph 10
R How do you tell if a rim is bent or warped Spridgets 1
J Bent camshaft for 64 BJ8? Austin Healey 1
K Bent trunnion fulcrum Triumph 21
G Bent a Lifting Eye.....Whew! Triumph 8
69MGC Any tips for fixing a bent boot lid MG 7
drooartz Bent pedestal stud Spridgets 13
pan Bent push rod Austin Healey 3
sultanoswing Bent Rims - fixable? MG 10
timbn2 Bent BN2 Steering Column Austin Healey 8
Webb Sledge Bent Valves/Head Gasket? Triumph 13
gsalt57tr3 TR2/3/3A TR3 Bent Frame Triumph 13
Webb Sledge TR6 TR6 Throttle Linkage Bent? Triumph 5
AUSMHLY bent frame Austin Healey 15
Guinn Bent bonnet MG 5
S TR4/4A Bent TR4 Frame Triumph 5
D TR6 Rocker arm assembly , pushrod clearance Triumph 8
K TR2/3/3A TR3 Brake MC pushrod? Triumph 0
T TR2/3/3A Clutch Pushrod hole location Triumph 4
D TR2/3/3A Pushrod tubes Triumph 4
brgrmyster GT6 67-68 GT6 Mk1 exposed pushrod tube color? Triumph 5
K TR4/4A Pushrod tube leaks? Triumph 2
dklawson General Tech Brake Maser Cylinder Pushrod Boot Installation Tricks? Triumph 2
R GT6 Early Gt6 Pushrod tubes Triumph 14
M_Pied_Lourd TR2/3/3A Brake and Clutch Master Pushrod Question Triumph 4
6 Recommended clutch slave cylinder pushrod clearance Spridgets 6
S TR6 Help! Need help from TR experts with this frustrating TR6 pushrod/rocker/valve issue Triumph 23
K TR2/3/3A Brake and Clutch MC pushrod/pedal bolt stops? Triumph 2
Rut Brake and clutch pushrod Spridgets 1
L Initial Adjustment of Pushrod on BJ8 Brake Master Cylinder Austin Healey 5
