Bent pedestal stud
drooartz
At least that's what the Moss catalog calls it. When I pulled the 1275 from the Midget, I hooked the hoist up to the 2 studs that come through the valve cover. I was worried about bending/damaging something, and it looks like I was right. The stud at the rear of the motor is slightly bent, so that the cap nut doesn't seat all the way down anymore.
Will I just need to replace that stud, or might I have done more damage?
bugimike
That is exactly what I was cautioning about in another thread recently, Drew! The topic was about engine removal and a few people stated that they use those studs, in fact there are even "lift brackets" available on the market (VB catalogue pp54 - #11) to attach chain hooks to those studs! I think there is too much risk to the valve train and would rather pick the engine up by the thermostat housing studs or the alternator mount up front and bell housing bolts at the back!
Check the whole pedestal carefully and make sure it is vertical, not leaning a bit. The camshaft rotates through this and if bent you could wear the camshaft bushings at the very least!
Cam what?
jlaird
From the old school I just use a couple of straps, one at front and one at rear.
bugimike
OOps, good catch Trevor I did of course mean ROCKER shaft, just a little old age brain fade...typing and thinking can get to be a challenge sometimes!! /bcforum/images/%%GRAEMLIN_URL%%/blush.gif
drooartz
drooartz
Too late for me to change how I removed it, unfortunately. Live and learn. /bcforum/images/%%GRAEMLIN_URL%%/blush.gif
Next swap, we'll use a different plan I think, but that's a ways off.
Sometime in the next few weeks I'll be separating the engine and tranny and getting the engine mounted on my engine stand. Tearing down and checking the engine is a good pastime while I'm saving up for my radiator and fuel tank work. I'll be sure to add checking the rocker shaft, if I can figure out how to do that. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
bugimike
If you have a decent manual, just follow proceedure. "Tab A into slot B" etc. etc. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
drooartz
drooartz
Good books I have, and of course there are all of you...
lesingepsycho
For the record, between my Dad and I, we've probably pulled and reinstalled 1275s 50 times or more by the studs without a single problem ever. There is nothing inherently dangerous in it but it sounds like perhaps you didn't have a large enough loop of chain between the studs. If you have just enough chain to go from the front stud to the rear stud with only enough space to fit the hook under, then it is easy to see that all of the stress is going to be at nearly a right angle to the studs. If you use a large high-arcing loop of chain, the stress is vertical and there is almost zero lateral stress on the studs. Chain, a come-along and a strong joist is all you need when done right.
JACK
drooartz
drooartz
What happened was that the rear bracket wasn't tightened quite enough, so the L bracket wound up with a little room to move around once I got things hanging. I caught it and tightened things up again, but that must have put just enough lateral stress on the stud to bend it slightly.
Bugeye engine removal should be a bit easier since the angle of the engine and transmission can be so much lower. That's a ways off, though...
paulsherman
Drew;
I just resently hung my engine and trany attached to an engine stand. I crudely fabricated a couple of brackets and fastened it to the side of the engine. Left side. Worked fine. Tonight I will remove the trany, check the clutch plates etc., clean it up a little and rebolt it to the engine. Works fine. Also able to install all of the stuff that goes on the right hand side. Can also roll it over and paint the underside of the engine.
Bruce_B
I keep looking at the engine stands for sale at Harbor Freight and can't imagine how the 1275 engine (or any A series engine) bolts on to them.
Any suggestions, pictures?
===NEVER MIND...Just did a search on ENGINE STAND reading all the rplies....Thks....===
B Bent frame rails near BE front end Spridgets 2
P Classic Tube Pre-Bent Brake Lines Austin Healey 5
PAUL161 T-Series Bent Push Rods MG 34
L TR2/3/3A Bent lower wishbone arms Triumph 6
C TR4/4A Bent pushrod Triumph 20
KVH TR4/4A Bent Valves Triumph 11
M TR2/3/3A Forward Carb Jet Lever Bent Triumph 12
B Overdrive Operating valve bent Austin Healey 15
J Healey 100 -- Broken rocker and bent push rods !!! Austin Healey 7
N Spitfire Should this be bent? Triumph 4
nevets pre-bent brake lines Austin Healey 7
M Bent Frame Spridgets 3
B TR2/3/3A is this a bent tr3b frame? Triumph 7
tinman58 Bent pushrods Triumph 69
J Disc rims all bent and out of round Triumph 11
bugedd My bugeye is bent Spridgets 31
jsfbond Flange bent? Triumph 6
glemon Bent Rear Hub/Axle Triumph 2
theleisure 3 out of 4 wheels bent, looking for new used set Spridgets 11
H TR2/3/3A TR3 Accelerator Shaft -- Straight or Bent? Triumph 9
I TR6 TR6 windshield frame bent? Triumph 8
19_again coil springs are bent Triumph 10
R How do you tell if a rim is bent or warped Spridgets 1
J Bent camshaft for 64 BJ8? Austin Healey 1
K Bent trunnion fulcrum Triumph 21
G Bent a Lifting Eye.....Whew! Triumph 8
69MGC Any tips for fixing a bent boot lid MG 7
pan Bent push rod Austin Healey 3
sultanoswing Bent Rims - fixable? MG 10
timbn2 Bent BN2 Steering Column Austin Healey 8
Webb Sledge Bent Valves/Head Gasket? Triumph 13
gsalt57tr3 TR2/3/3A TR3 Bent Frame Triumph 13
Webb Sledge TR6 TR6 Throttle Linkage Bent? Triumph 5
AUSMHLY bent frame Austin Healey 15
Guinn Bent bonnet MG 5
S TR4/4A Bent TR4 Frame Triumph 5
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
S TR2/3/3A Installing the distributor pedestal. Triumph 3
J Wanted WTB TR 3-4 Generator pedestal Triumph Classifieds 3
M TR2/3/3A Rocker Shaft Pedestal Lock Washers Triumph 4
T TR4/4A Distributor Pedestal Mesurements Triumph 2
D TR4/4A distributor pedestal shim [packing] quandary Triumph 6
E TR4/4A TR4 Distributer pedestal Triumph 13
CJD TR2/3/3A Rocker Pedestal Triumph 9
M Rocker pedestal stuck...! Austin Healey 7
M Bajo bolt and rocker pedestal threads.. Austin Healey 6
TulsaFred engine lifting with pedestal stud brackets Spridgets 22
PatGalvin Distributor Pedestal Tach Drive Triumph 2
K TR2/3/3A TR3A generator to pedestal bolt? Triumph 3
texas_bugeye Rocker pedestal Height Spridgets 9
