Another possible cause would be the valve seized in the guide due to lack of proper clearence for the vlave stem to guide ID, more commonly this happen on the exhaust valves and with bronze guides. One thing non British car machine shops and engine builder struggle with is our bronze guides, some of them use bronze liners, but thats nothing more than a sliver of bronze and the clearence is not much different than that of what they are used to working with, but with our bronze guide inserts, they are thicker than the bronze liner and because of this need more clearence at room temps when sizing, due to the fact with the thicker bronze guide they will tighten up at normal engine temps, this has stumped more than one machinist or builder, who is not familar with theses engines and our bronze guides. The bronze guides we use in these engines require about .003"-.004" clearence or you could have a issue, the exhaust is of course the normal culprit due to the extra heat on that side, and if not clearenced enough they would tighten up grab the valve, and from there can/could bend the push rod, break rocker arms, damage cam lobes and lifters.
