Yeah, I read about some cranks bending if stored incorrectly. But, if USED bent, you should have a "radius ride" show up in the bearings......being a very worn spot on one side or the other, all the way around upper and lower.
How far down was it torn when you did this rolling test? Pull the timing chain and do it again. Then pull the pistons one at a time and do it again.
