Bent pushrods
Thanks Paul.
I just saw that post and sent him a e-mail. Got the supercharger off and the oil cooler off and drained,and a few other things done tonight.Gonna pull the motor on Sunday. Thanks for the offer Paul but I think this guy might work out.
Hopefully that works out :thumbsup:
Just picked up a new head this evening. Going to the machine shop on Monday to do there magic.. Funny thing about the supercharger it makes your right foot about 2 lbs heavier than normal...
....and your wallet lighter.
Cheers,
M. Pied Lourd
Just spent the day removing the engine and did a complete tear down. When I got to the crank it would spin free for 180 degrees then bind for the other 180 degrees. The main bearings looked good. ???
As for the valves the # 8 exhaust and #1 exhaust looks like they were up in "the bowl"
I am going to take all the moving parts to the machinist tomorrow. I understand the valves (got a new head on Friday) But the binding concerns me.......
As it should. Most likely, it means the crank is bent.
Dumb question . But how does a crank bend?
I've heard of them bending enough to cause problems, just being left laying sideways on a shelf (so they should always be stored standing vertically if not inside an engine block).
Otherwise, I don't know the mechanism, only that iron and steel sometimes distort a bit with heat cycles and age. Any machining operation (like grinding the journals) can cause them to distort as well. (So any good crankshaft service should be able to straighten it for you.)
Thanks Randell!
As always you are a great source of Knowledge!
There was only .003 of clearance of the thrust washer could that have caused the binding?
Yeah, I read about some cranks bending if stored incorrectly. But, if USED bent, you should have a "radius ride" show up in the bearings......being a very worn spot on one side or the other, all the way around upper and lower.
How far down was it torn when you did this rolling test? Pull the timing chain and do it again. Then pull the pistons one at a time and do it again.
If you are dissasembled to the crank I think it must be bent crank or distorted block or bad set of bearings.Can you still get the .003end play when you have it in the tight area?
Tom
It was disasembled to the crank. The main bearings look good. But one of the connencting rod bearings is showing a lot of wear. It was the #4 piston. There was only about 12,000 miles on this motor
Update.... Machinist say the crank is cracked..... How much for a used one?
but my used one is cracked!
If you are going all out with this engine why not look for as billet steel crank. Moldex makes one for TR3-4's. Not cheap, but hey as our friend says, "it's only money." LOL
John
Just my opinion, but I'd say the price depends on how big a hurry you are in. Whole blocks show up pretty frequently for cheap money, so you could score both a crank as well as a spare head with a little time.
B Bent frame rails near BE front end Spridgets 2
P Classic Tube Pre-Bent Brake Lines Austin Healey 5
PAUL161 T-Series Bent Push Rods MG 34
L TR2/3/3A Bent lower wishbone arms Triumph 6
C TR4/4A Bent pushrod Triumph 20
KVH TR4/4A Bent Valves Triumph 11
M TR2/3/3A Forward Carb Jet Lever Bent Triumph 12
B Overdrive Operating valve bent Austin Healey 15
J Healey 100 -- Broken rocker and bent push rods !!! Austin Healey 7
N Spitfire Should this be bent? Triumph 4
nevets pre-bent brake lines Austin Healey 7
M Bent Frame Spridgets 3
B TR2/3/3A is this a bent tr3b frame? Triumph 7
J Disc rims all bent and out of round Triumph 11
bugedd My bugeye is bent Spridgets 31
jsfbond Flange bent? Triumph 6
glemon Bent Rear Hub/Axle Triumph 2
theleisure 3 out of 4 wheels bent, looking for new used set Spridgets 11
H TR2/3/3A TR3 Accelerator Shaft -- Straight or Bent? Triumph 9
I TR6 TR6 windshield frame bent? Triumph 8
19_again coil springs are bent Triumph 10
R How do you tell if a rim is bent or warped Spridgets 1
J Bent camshaft for 64 BJ8? Austin Healey 1
K Bent trunnion fulcrum Triumph 21
G Bent a Lifting Eye.....Whew! Triumph 8
69MGC Any tips for fixing a bent boot lid MG 7
drooartz Bent pedestal stud Spridgets 13
pan Bent push rod Austin Healey 3
sultanoswing Bent Rims - fixable? MG 10
timbn2 Bent BN2 Steering Column Austin Healey 8
Webb Sledge Bent Valves/Head Gasket? Triumph 13
gsalt57tr3 TR2/3/3A TR3 Bent Frame Triumph 13
Webb Sledge TR6 TR6 Throttle Linkage Bent? Triumph 5
AUSMHLY bent frame Austin Healey 15
Guinn Bent bonnet MG 5
S TR4/4A Bent TR4 Frame Triumph 5
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
J TR2/3/3A Rusty pushrods Triumph 1
TomMull TR2/3/3A TR3 pushrods; Nothing seems simple any more Triumph 2
JFS TR2/3/3A Pushrods Triumph 16
Jim_Gruber Adjusting Pushrods in Pedal Box Spridgets 5
H Triumph TR Pushrods //rockers?? Triumph 24
H Tr 3 head and pushrods Triumph 12
OZ_BN1 Pushrods Austin Healey 0
TR6oldtimer Pushrods not rotating Triumph 2
jvandyke master cylinder pushrods sought Spridgets 8
69MGC Need Pushrods for Pre-71 engine MG 24
