Webb Sledge
Ok, so here's the story. It's not about a Triumph, but I figure engines are similar enough and you guess could still probably take a good guess at the problem, especially the guys who have worked as mechanics at one point or another:
I've been looking around for an E36 ('94-99) BMW M3, and I found one, but it has one problem. I called the guy and he said he was in Maryland visiting family and he turned to go up a hill and hit the gas to accelerate and lost all power. The car was towed to a local BMW dealership, and they replaced most of the ignition components to no avail before running a compression test to find that cylinders 5 and 6 could hold almost no compression at all, and 4 fluctuated between 80 and 100. Since they didn't pull the head, their best guess was the it was either bent valves or a blown head gasket. They also replaced the camshaft sensor, and the problem remained.
I'm not an expert, but I just don't see how the car could bend valves like this. Again, I'm not sure, but I don't think the M50 engine (what the M3 uses) is an "interference" engine. The reason I ask is because this would make a great deal for me if I could buy this car and have something simple like a head gasket replaced, but it would require me spending almost $2500 more if it was indeed bent valves.
The current owner also mentioned how the dealership told him it would cost him $6000 to replace everything with labor, and then made him an offer on the car for $10,000, basically trying to get him to sell the car. I can't verify this, but in my experience with car dealerships this doesn't sound to far fetched. The owner also said he bought it last year for $21,000 and needs four wheel drive right now and he just got married so he can't afford to fix it.
Any ideas as to what the problem could be? BMW charges an arm and a leg just to pull the head and check it out, so I'd really like to have a good idea as to the problem before I get into this one.
