MGB Hif’s Rear leaking gas
bobnorway
Did a carb change from a single Strom on my 77. Rebuilt HIF’s and changed all the stuff needed but when I turned pump on rear carb leaking gas. Front seemed ok.....float problem? I did check for crackers before installing and seemed fine. Put in new needles with rubber tip. Might be stuck? Also do carbs have to come off ? :(
JPSmit
Bob, welcome and sorry to hear of this. At this point literally the only advice I can offer is point out that you have posted it in the thread that helps people navigate the software of the forum itself. So, pretty much no chance you are going to get an answer. (except mine :grin: )
Can you repost in the forum of the make of your car? Or let us know the make and I am sure a moderator can move it.
Good Luck!
Administrator
Boss
Bob, as JP said, you posted your question in the wrong forum. The forum you posted in is for asking for help, as JP said, in how too navigate the forum. Since I see in your profile you have a 77MGB, I'm assuming this should be in the MG forum, so I'm moving it. When you next see this thread, it will be in the MG forum. I'll leave a pointed in the original forum to direct people to the thread in the MG forum.
Mickey Richaud
Hi, Bob, and welcome!
Yes, they do have to be removed to check floats, etc. - a disadvantage of HIF carbs.
Mickey
Platinum
Try *GENTLY tapping on the carb body with a screwdriver handle as the pump is running. Sometimes the needle gets a bit out of alignment and a tap or two may seat it... if not there's no choice but to disassemble the thing and find out what's wrong.
PAUL161
Bob, Who's float valves did you replace the old ones with? I've had problems with the newer "Gross" valves bypassing, (not seating right). PJ
Platinum
Gross Valves are evil and wrong. o back to brass.
Tybalt
It's somewhat unlikely but I have seen HIFs leak from where the counterbored screw that holds the float pin in place fits into the carb body. As for Gross jets, not a fan of those myself.
dklawson
I removed Grose Jets from my cars also. I have had them stick open and stick closed but never work correctly. I now run the Viton tipped traditional float valves.
HOWEVER, recently I bought generic Viton tipped float valve kits from one of the usual sources. The brass seats for the needles were poorly made. Neither sealed properly. I re-used the old brass seats with the new needles and all seems well. Keep that in mind when you order your float valves. Get the genuine Burlen/SU parts if possible.
Platinum
A bit of personal opinion now: get the carb parts from joe Curto.
Mickey Richaud
maynard
Sorry to hear of your troubles. Consider joining the Chicagoland MG Club (chicagolandmgclub.com), if you haven't already done so. We are a wealth of mostly correct knowledge, and have several members in Downer's Grove.
We are having a British Car Swap Meet this Sunday at the DuPage County Fairgrounds.
GBRandy MGB HIF float chamber seals MG 6
R 1275 engine with SU HIF single carb Spridgets 9
R HIF Carbureter British Motor Corp 2
M SU HIF 44 crab problem Rover / Land Rover 5
wkilleffer MGB Anyone still use HIF SU carbs? MG 12
RickB General Tech Need pictures showing how to connect choke on HIF carbs. MG 2
B TR6 Hitachi HS6 HIF rebuild/TR6 Triumph 1
PAUL161 72 HIF Butterfly - Moss Part Number MG 15
PAUL161 HIF Throttle Disc MG 10
A HIF tweaking Spridgets 11
M HIF 44 Choke Spridgets 10
H HS4 to HIF inlet manifold question MG 2
PAUL161 Doc, Tony, HIF SU434 Carbs Vers. SU493s . MG 4
PAUL161 SU Carbs HIF-4 # AUD 434s What are they off of ? MG 5
PAUL161 HIF-4 Question ? Need some answers! FOUND ANSWERS! MG 0
PAUL161 Question -- 25D-4 vac hose connection with HIF-4s MG 7
A new guy-74 B, HIF question MG 15
D HIF carb info request MG 3
Moose33 newbie question about HIF's MG 2
Thor What Needle Used for HIF-6 on 1500 Spridgets 3
Thor HIF-6 Needle/Jet Recommends for 1500 Spridgets 0
W MGB 73 MGB HIF Hoses MG 8
A HIF 4 Carbs MG 6
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
B Rear Brake Cylinders Austin Healey 4
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
