TR6 What goes here? [TR6 pictures attached]
tdskip
Still debating about painting here, but in any case I need to get the interior sorted at some point.
Can anyone identify what these holes on the rear deck are for?
I put white arrows where the holes are - and they are symmetrical from side to side.
Thanks!
G
If they are on both sides, somebody had a roll bar installed at one time.
G
If you are going to paint, that sheet of tar should be peeled off, can be done with a sharp, wide chisel, a mallet and elbow grease.
T
tdskip
Oh - duh. Seems kind of obvious now that you state it Bill.
I'm not planning on installing one so I think I'll just weld up those holes and be done with it.
And yes, all that crap will come off before anything gets painted.
Thanks!
mrv8q
Tom, FWIW, here's a pic of my unmolested one:
mrv8q
tdskip said:
Is yours Maple or Sienna brown?
Whichever is uglier.... one day I hope to buff it out; right now it's a faded baby-poo brown ...
DougF
Always fun to weld right beside the gas tank. What precautions do you plan to take?
kodanja
Were those holes for a former Roll Bar?
T
tdskip
I was going to put the cigar out first - lol.
Actually I was planning on putting the metal/foil back heat shield material up as a temporary barrier first. Stray sparks here don't seem like a good idea - thanks for asking Doug.
Kodajna - yes, the leading threoy was that there was a roll bar there at some point.
kodanja
I thought so cuz they line up right where mine are
kodanja
the smaller ones look ok too
DougF
You might want to seal the throat of the tank since the gas cap seal is good against liquid, but not necessarily fumes. Once sealed, you may even be able to relight that cigar. :laugh: ...not!
TR6oldtimer
TD get a roll bar or use rubber plugs to fill those holes (that's what Triumph did), a whole lot less expensive.
AngliaGT What Goes Here? - Holes Behind Rear License Plate Mount Spridgets 3
catfood What goes here Austin Healey 6
JPSmit and what goes here Spridgets 11
JPSmit what goes here Spridgets 8
AweMan Help, What goes here? Triumph 5
mylillooker What the heck goes here? Triumph 2
J Another "what goes here"? MG 2
J what goes here? MG 6
DrEntropy MGB Head gasket R&R goes on... MG 13
TR6Canuck TR6 TR6 waist seal clips - which side goes on which part? Triumph 6
R Turn Signal Knob goes off center Austin Healey 9
Editor_Reid 2011 Aston Martin V8 Vantage N420 Goes Full Lockdown Other British Cars 54
K TR4/4A Adapter that connects Clutch MC to the pipe that goes to the slave cyl? Triumph 4
MadMarx Wedge IMSA TR8 goes on Salzburgring Triumph 6
HealeyRick Pretty, Pink and it Goes Like Stink! Spridgets 5
M TR4/4A What goes in these holes? Triumph 6
AngliaGT What Goes to the Left of the Tach? Spridgets 3
B Clutch disc - which side goes towards flywheel? Austin Healey 8
jaegzie Turn signal wiring on back of switch. What goes where. Spridgets 6
drooartz My Jeep goes convertible Other Cars 6
S TR2/3/3A the slave cylinder goes Triumph 7
bugedd Bet this things goes like heck Spridgets 4
rjc157 tach goes crazy Austin Healey 8
2billydavies TR2/3/3A anyone know what this valve is and where it goes on a TR3a? Triumph 14
toysrrus TR2/3/3A What Oil goes in your TR3/4 Trans? Triumph 14
K TR2/3/3A Odd Clutch Failure...Clutch crosshaft bushing goes for a walk! Triumph 6
RAC68 Torn Frameā€¦and the Saga goes on Austin Healey 20
T TR6 TR6 goes, dies, goes, dies, Etc Triumph 33
M Car goes "click" when trying to start - the fix Spridgets 8
drooartz Tunebug goes to the doctor Spridgets 16
boeingpilot TR4/4A TR4A seems to "wander" as it goes down the road Triumph 20
BugeyeNJ58 New gauges in Dashboard where radio goes... Spridgets 5
drooartz Tunebug goes to work Spridgets 18
T Temp gauge goes off the scale Triumph 29
elvacar Elva - She Goes Far Other British Cars 9
K TR2/3/3A TR3A: Petronix Pos ground...which wire goes where? Triumph 6
Trevor Jessie New engine goes Vrooom.... Spridgets 31
AngliaGT Austin Goes Racing in NASCAR Racing 8
T Differential goes "klunk!" Triumph 9
CCURTISS T-Series MGTF Firewall [what goes in what hole] MG 2
Jim_Gruber Starter goes Click-Oh how easy this car is to fix Spridgets 1
Trevor Jessie When a fun job goes bad... Spridgets 51
T Wedge There goes another TR8 Triumph 11
2wrench Picture of my head after piston goes bad. Triumph 29
rlandrum The List goes on... Triumph 14
ronzet And the beat goes on... NEW PHOTOS MG 16
Brosky When a good cylinder head swap goes bad... Triumph 34
B MGB MGB Cuts out, Tach goes dead..... MG 18
jlaird This goes to Miss Agathas first show. Spridgets 24
G Green/Purple or Red --- Which wire goes where???? Triumph 12
