What are these screws on the carb
tomgt6
I have a 70 gt6 with stromberg 150cd carbs. I found that i have a model with adjustable needles or are spring loaded. But I have read the haynes manual and still lost.
I no what the idle screw is. But on the other side I have two other screws.
The bypass screw and the idle mix screw.
What do they do and were should I set them to start. Do I also need to adjust the needle and if I pull it up what does it do compared to going futher down.
Lost Sorry for any of you who is going to try and explain this. Thanks for the help. Tom
T
tomgt6
h
Rick O.
If the 150's are similar to the 175's, the idle screw is on the left side of the carb and mates with a lever attached to the throttle shaft. For an initial adjustment (with the folded linkage couplings loose), just turn that screw until is contacts the lever, then one more turn. When done, tighten the folded couplings.
An initial setting for the adjustable needles is 2 turns CCW from full rich. Full rich is obtained by turning the needle CW until the needle bottoms-out (can't turn anymore).
Good luck.
V
vagt6
Hey Tom, a Bentley Manual would be of great help in your repair efforts. The Bentley for your specific GT6 model has highly detailed schematic drawings and suggestions for tuning your Stroms.
Get one, you'll be glad you did.
Bugeye58
My factory book says that no difference in running will be noted by ear whether the idle trim screws are all the way in, or all the way out. They are to set the exhaust CO content by using a gas analyzer. Go figure.
Jeff
M Wanted: 2 Fast-idle adjusting screws for HS carb Spridgets 5
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
PAUL161 T-Series 55 TF Floorboard screws MG 4
J TR4/4A Washer bottle bracket screws Triumph 3
S TR2/3/3A the large Philips headed field screws Triumph 12
somewhatspritely Mystery Screws Spridgets 5
BN6_2197 BN6: How to case spikes of the screws of the door panels Austin Healey 17
S TR2/3/3A Stubborn door hinge screws in “A” Post Triumph 6
K TR2/3/3A The 3 Steering Wheel "Grub Screws" and the Control Head. Triumph 2
S TR2/3/3A bottom of the grill screws Triumph 3
Basil 7 Ways to remove stripped screws Restoration & Tools 2
6TTR3A TR6 TR6 Trunk lock set screws Triumph 2
Floyd Tiwater TR2/3/3A Top stick screws Triumph 8
D Stromberg Dash Pot Screws Jaguar 3
Jim_Gruber Screws for HS-2 carbs Spridgets 5
Joe Schlosser BE windshield screws Spridgets 4
R TR2/3/3A 1961 TR3A's Nuts, Bolts and Screws Triumph 5
aero3113 100 Windshield screws Austin Healey 3
Jim_Gruber 1/4 Elliptic Spring Clamps - Are those Whitworth Threads on those 1/4 Screws Spridgets 7
K TR2/3/3A Another windshield question...bolts and screws? Triumph 15
F How to restore screws, springs and fixings on SU HD6 Carburetors? Austin Healey 7
Tinkerman TR2/3/3A Rear upholstry panel screws Triumph 2
K TR2/3/3A Side Curtain bracket Dzus screws. Triumph 2
Jim_Gruber Source for PosiDrive Screws Spridgets 7
T "Cheese-Headed Screws" on Armstrong lever arm shocks Spridgets 2
jfarris TR2/3/3A Thumb Screws for Wedge Side Curtains Triumph 4
Scot1966 TR6 Screws in TR6 spare tire well Triumph 12
C TR6 Convertable top mounting screws Triumph 5
catfood Self tapping screws an rust prevention Austin Healey 10
Tinkerman TR2/3/3A Phillips Head Screws Triumph 8
GlennG TR4/4A TR4A Fender Screws - Source? Triumph 5
M Screws vs bolts for pedal box attachment to body Spridgets 6
T TR2/3/3A Interior panel and carpet screws Triumph 1
J TR2/3/3A Hood lift to front apron, what size are the screws that go from bottom up? Triumph 10
B TR6 need 2 air extraction grilles and bezels, screws and nuts Triumph 6
L Thread size, indicator head to stator tube screws Austin Healey 0
T TR2/3/3A front fender bead screws? Triumph 12
luke44 TR2/3/3A TR3 Door Panel Screws - Location - How Many and Where? Triumph 10
B Bleed Screws Spridgets 2
D Drum retaining screws Spridgets 11
bugedd Brake bleed screws Spridgets 6
luke44 TR2/3/3A TR3 Windshield Stanchion Short Screws Long Screws Triumph 2
O rear view mirror screws Austin Healey 5
J Busted Fuel Tank Sender Unit Screws Austin Healey 7
O TR2/3/3A TR3 Turn Signal Retrofit / Windshield Screws? Triumph 7
B Best screws for woodwork to BJ7/8 hood frame Austin Healey 5
Rut Windshield screws Spridgets 5
B Those little tiny screws Triumph 4
