Stromberg Dash Pot Screws
DJames
Car is a '69 E-Type with dual Strombergs. The top (dash pot) is held on by 4 screws. I noticed a while back that one of the 4 screws is longer than the other three on both of the carbs. I was talking to a parts guy at one of the Jag parts distributors and asked him about that. He said that he vaguely remembered once at a show seeing this and that the longer screw had a hole drilled in it. He recalls that there was a wire going thru the hole with a small piece of lead crimped on it. He doesn't remember what the crimped lead looks like and has no idea what it was for. Does this ring a bell with anyone?
Just curious,
dj
Grantura_MKI
Yes.
they where set at the factory....no need to reset.
You should switch out to adjustable needles.
My restored car as them, but new dash pots fitted.
Geo Hahn
The lead seal on mine...
Okay, I'll admit I have a seal maker -- I do open them up.
I installed TR4 adjustable jets to make it easy to dial in the mixture - otherwise you are left with moving the needle a bit or taping down the fixed jet.
J Stromberg Dash Pot Oil Triumph 13
S TR6 Stromberg Bypass Valves - Question Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 2
M General MG stromberg carb MG 5
Sarastro TR4/4A Stromberg linkage question Triumph 4
SherpaPilot TR6 Stromberg War, Finally Success Triumph 2
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
steveg Online SU and Stromberg needle database with comparison charting Austin Healey 2
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
R GT6 Carb Floats for Stromberg 150 . Triumph 5
B Zenith Stromberg O ring question Other British Cars 8
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
K TR4/4A Stromberg question. Triumph 13
SherpaPilot TR6 Stromberg CD 175 Carb Tuning Triumph 8
M TR4/4A Stromberg CD175carb query Triumph 7
RickB MGB Stromberg on my 80 MGB - fast idle this morning MG 6
RickB MGB HS6 or HIF4 bolt right on in place of Stromberg? MG 6
Zimmycobra TR4/4A Zenith Stromberg questions Triumph 13
M TR4/4A Stromberg ? Triumph 4
L zenith-stromberg carbs Lotus 11
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
G Stromberg cd150 question Spridgets 1
TR6BobNF General Tech Midget Stromberg 150 Adjustment MG 8
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
W Weber/stromberg air cleaners Jaguar 3
dklawson Early Stromberg Floats - 150CD Triumph 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
W Zenith stromberg carbs Jaguar 3
J stromberg float source or x referance Triumph 2
L Stromberg 175 cd question Other British Cars 5
D TR6 76 TR6 Stromberg Air Valve Triumph 2
H Stromberg Carb Sync and adjust Triumph 6
T Stromberg Triumph 22
sundown 175cd stromberg carbs Triumph 4
JPSmit Stromberg Carb Question Triumph 15
R TR4/4A Tr4a, Stromberg float setting Triumph 6
regularman I found the fix for the stromberg on the 1500 Spridgets 6
A XKE Series II Stromberg Carb Upgrade Jaguar 4
C Stromberg carbs Triumph 8
R TR4/4A Tr4a, Stromberg rebuild Triumph 6
glemon Rebuilding stromberg Carbs Throttle Shaft Bushings Triumph 6
TR4 Stromberg Choke Issue Triumph 3
S Question on rebuilding Stromberg carb Triumph 24
R Zenith Stromberg CD 175 float replacements? Triumph 3
F Spitfire Spitfire 1500 - Stromberg CD 150 Question Triumph 9
R TR4/4A Tr4A , Stromberg carburetor Triumph 20
R Stromberg adjustment screw tight 175CD Triumph 10
T Gas leaks from the bottom of my Stromberg carbs. Triumph 7
